Results 1 to 10 of 337
January 2nd, 2009 09:09 PM #1
I had one installed in one of the vehicles today. It's features (and transmitter) are similar to the more basic models of Autopage. Not the cheapest system on the market at SRP Php1,600.00++ but I chose it for the following reasons:
*Autopage-look trasmitters that do not have tons of plastic chrome or look like spaceships as some Taiwan transmitters do.
*None of that flashing parklight thing when you open the door so common in Taiwan alarms. Some people like this feature, I don't.
*The siren sounds like an Autopage and not your neighborhood tricycle or jeepney 'wang-wang'. The arm and disarm chirps are also very European.
*Separate shock sensor with knob adjustment (no need for a micro screwdriver to adjust sensitivity).
*Anti-carjacking feature (engine disable and alarm triggers if programmed to do so)
*Password override (no valet switch that everyone knows is just under the dash)
*Starter disable when system armed (just like in more expensive systems)
For those looking for a system, this might be a good option.
The OEM keyless entry (without alarm) was also not disturbed during this install should there be a wish to revert back to the original system in the future.
The new system also flashes the turn signals (not the park lamps) to make it look like an 'original' security system. You can request the installer to do this.Last edited by OTEP; January 2nd, 2009 at 09:19 PM.
- Sep 2008
- 1,219
January 3rd, 2009 10:17 AM #3maganda to..saan po kayo nakabili? most of the stores like BLADE ayaw installan ang Mazda 3 ko, mavovoid daw ang warranty?
January 3rd, 2009 10:35 AM #4
+1 sir... san mo nabili this alarm? plan kong magpalagay ng alarm for my Sentra GSX.
January 3rd, 2009 01:42 PM #5
I got it from my long time (10 years plus) electrician who now freelances in Banawe. His name is Jameson (09215711924). Just tell him, Dr. Rivera referred you to him. He frequents the radiator shop in front of Sogo Banawe (directly in front of the artifical flower shop)
You can also shop around.
January 4th, 2009 04:52 PM #6
Pardon if the images are too large.
System during install (siren installed already):
System features:
System components (again, siren not shown):
January 4th, 2009 05:03 PM #7
January 4th, 2009 05:10 PM #8
Yup. That's what the manual override is for. Unlike before where there is a switch dangling from underneath the dash, this system uses a password. For obvious reasons, I will refrain from discussing how the password override works. All I can say is you will just need your car key and a good view of the LED warning lamp to override the system.\
I also asked my installer not to install the alarm control unit box under the dashboard. The long wires included means it can be installed in a more discrete place. Some less popular places include, kick panels, behind the center stack (behind the audio/HVAC system), in the passenger side of the dash, etc.
February 11th, 2009 10:36 PM #10
Not as far as those old Cobra Units (4th floor UST Main Building to the vehicle parked on the then front parking (now its a pedestrian park).
About 3-5 cars away as you approach it on the parking lot. You can reposition the antenna wire to get better range.
If you think about it, if the price of the battery does not go down, replacing the battery of a...
Mitsubishi Xforce
