Page 164 of 176 FirstFirst ... 64114154160161162163164165166167168174 ... LastLast
Results 3,261 to 3,280 of 3510
    Feb 2005
    #3261
    by the way i read somewhere that the maximum length of a usb cable is 25 meters before it loses signal
    Sep 2016
    #3262
    Spare cord I found at home, from CD-R king I think. Around 2 meters long.
    Thanks sir. Will try to buy an extension cable to test if it will do.
    Sep 2016
    #3263
    Quote Originally Posted by box_type View Post
    Bitin kasi yung included cable eh. I think 2 meters ata yun. I need at least 3 meters more para umabot at maayos/malinis ang pagkakalatag ng wire sa loob ng sasakyan.
    #3264
    provided it is STANDARD yun gauge ng wires, you can go as long as 10 meters.
    Jul 2013
    #3265
    I've seen YouTube videos na may parang clear plastic na linalagay sa windshield bago idikit yung dashcam...
    Has anyone installed something similar?
    Tinted kasi windshield ko, if I use a suction, baka masira yung tint... Yung adhesive naman, hirap linisin kung maisip ko magpalit ng cam
    #3266
    subukan mo mobile phone screen protector
    Jul 2013
    #3267
    yun nga naisip ko kung wala talaga akong makita... hanap ako ng cheap phone screen protector... sana dumikit
    Mar 2007
    #3268
    Nic Chua - Really?!? Counterflowing na, singit pa! From... | Facebook
    Bwisit na Adventure
    Sent from my RNE-L22 using Tapatalk
    Mar 2007
    #3269
    Anyway, it's a good sample of the Yi Rearview Dashcam's rear camera.
    Apr 2006
    #3270
    so bale the layers would be in the order of glass, tint, screen protector, adhesive, and lastly, the camera mount?
    wondering if the screen protertor can hold the weight of the camera+mount.
    Jan 2018
    #3271
    I am using a blindside mirror to mount my dashcam, much reliable than plastic which react to heat and bulge overtime.
    Nov 2017
    #3272
    Quote Originally Posted by Brentt View Post
    Pics please. You can upload it at postimage.org then copy/paste the hotlink for forums here.
    #3273
    mas maganda parin talaga mini dashcam ni bro jut.
    this is OEM vlt 35 already and sobra na clarity nito, borderline clear na IMO.
    vkool oem VLT 35 (not much difference from VLT 20) - YouTube
    eto no tint unfair comparo as well lit yun areas nadaanan, but you get the idea.
    DDPAI no tint 1(5) - YouTube
    Apr 2018
    #3274
    Ano kayang quality dashcam na within 1-1.5k? Gagawin ko lang rear camera. Madami ako nakikita online pero sana yung magtatagal kahit di sobrang linaw.
    Apr 2010
    #3275
    anyone have (blueskysea?) B1W camera?
    it's 1080p and capacitor based, no screen so settings and video review are done via wifi.
    same form factor and hardware as the xiaomi 70mai but that has a battery.
    the qube a7 i got 3+ years ago is starting to act up. might be fixed by replacing the battery pero i removed the windshield tint kasi so i think it affected the lifespan
    it is in the 2k range, and an upgrade to the g1w-c cameras
    Dec 2004
    #3276
    Quote Originally Posted by ParticleX View Post
    I use a Blueskysea B1W. I like it except for the over sensitive gyro sensor but other than that everything's working well
    Dec 2018
    #3277
    Hi! Do you have any suggestions for a dash cam with most if not all of these features:
    1. 3 cameras (front, inside, rear)
    2. Good quality images/videos for both day and night (at least for front cam)
    3. Can view recorded media remotely (via 3g or 4g)
    4. Has LCD screen
    TIA!
    Sent from my SM-G950U using Tapatalk
    Dec 2017
    #3278
    Quote Originally Posted by ziggyzagged View Post
    4. Has LCD screen
    TIA!
    You might want to check this out:
    DIY: 360 Camera And Dashcam Setup - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
    Items 1,2, and 4 are covered. I haven't tried if item 3 is possible.
    I'm contemplating to dismantle the "inside camera" and remove the frame because I find it too big. Another option is to replace the said camera with a smaller one.
    Sep 2016
    #3279
    Is a 128GB SD card enough to cover at least 12 hours of driving before looping back to the start and overwriting the existing videos? I am planning to document my drive from Manila to Mindanao if ever that will come to reality within the year.
    Apr 2014
    #3280
    The other question is, does your dash support 128gb?
    In my dashcam, a 5minute 1280x720 30fps vid consumes around 200mb.
    Just fill in the blanks:
    (zz) shots per hour x (yy) mb x (xx) hours = ? mb
Blackbox DVR/Dashcam
