I have checked the maximum memory it (DDPAI mini 2P) can handle and it says it can use up to 128GB max. Kapag mukhang matutuloy na yung trip namin, tsaka na lang ako bibili.
Thank you for the info sir. Pag long break siguro para kumaen, kunin ko na yung nasave na video para sure.
Mga Boss
Ano recommend nyo for dash cam worth 2K, more or less. Thanks
Bought a 70mai Dash Cam Pro for our Toyota Rush, but the dealer says they won't install my cable since the camera didn't come from them. Hesitant to install the cable on my own because I might get in the way of the deployment of the side (curtain) airbags. Ano ang puwede gawin dito?
Bought junsun A930 dual camera... so far the interface seem responsive... i can use the rear camera just like the nissan terra feature pag puno ang likod you can still see who’s behind you... [emoji4]
Junsun A930 10 inch 4g support car gps navigation description - YouTube
Ohhh... which area yung dangerous part na ma deploy yung airbaigs when installing dash cam wire?
I have mine ecosport and cruze before pero im not aware na meron pala ganyan... now, i will try to install it in terra and cx5(soon) but with the post above i have to be carefull since both of them has curtain airbags ...
https://i.imgur.com/5BL8qzx.png
I'm particularly concerned about the area in green. I'm not keen on disabling the airbags to do this (sorry) pero ayoko din maharangan ang side airbag sa paglatag ng wire. I'm just not that sure whether running it down the side of the windshield will cause any interference.
Parang same kami ni jut...
Ganito yung set up ko previously... pero sa windhsield
Area yung wire instead dun sa part ng passenger window side... naka tago lang dun sa plastic cover...
Tapos sa rear cam ganito, sa baba ko dina.an...
there is a lot of space inside the A pillar. airbag "modules" are not that big.
Installing Dash Cams on Vehicles with Airbags - BlackboxMyCar - YouTube
Last edited by EricDraven; July 5th, 2019 at 05:08 PM. Reason: error in formatting
Buksan mo lang enough yung A-pillar cover para malusot mo yung cable sa pagitan ng airbag and A-pillar. Bale sa driver side ako nagpadaan ng cable. Yung direction ng insertion ko was sa left side ng A pillar. Yung connector sa cable to dashcam ang nilusot ko then hatak nalang papunta dashcam. I did this sa CR-V with airbags on A-pillar
Tape the dashcam cable onto the A-Pillar behind the airbag, if car is equipped.
Diyan ako medyo nangingiming magkalikot ehmost videos sa YouTube ng naglalatag ng wire, isinusuksok lang yung wire along the crevice. Meron naman iba na nagtutungkab ng cover like what you did, pero hindi maganda ang track record ko sa mga pagbukas-bukas ng mga ganyan
nakakatakot makabasag ng clip or whatnot, esp. with a car this new. But thanks for the image, it's a big help. Ano'ng oto ito?
