Page 228 of 351 FirstFirst ... 128178218224225226227228229230231232238278328 ... LastLast
Results 2,271 to 2,280 of 3510
    May 2009
    #2271
    Quote Originally Posted by DannyJr View Post
    Then sa baba ng side, I taped it near the floor and up to the underside of the glove compartment:
    I used electrical tape para di masyado obvious. You can use double-sided tape pero nakabit ko na ng electrical tape so di ko na binago.
    pwede nyo sir tanggalin yang plastic cover ng kick panel at jan sa loob nyo isingit yung wire. mas malinis tignan. or maari namang ipwersa paloob yung wiring jan. alalay laang.
    Sep 2016
    #2272
    Quote Originally Posted by miked View Post
    Malakas naman loob ko. Try ko mamaya. Mali kung mali, tama kung tama!
    Subukan mo munang isiksik lang. May space yan between the plastic molding and the fabric.
    🎗Shine the light! 🎗
    May 2013
    #2274
    Hi guys,
    We got a dp220, that's been in the box for some time now (bnew), and I am now planning on installing it on my car. Problem is, yung car charger is a bit too close sa gear shift, plus prone sa sabit when exiting the car (exit only to the passenger door coming from the driver's seat). I was thinking of replacing the cable to a usb type that would be powered by the same phone charger that's installed on the cig power supply.
    I've scoured all the pc shops and cable monster, but to no avail. Do you have any lead/s to a reliable supplier? I'm primarily looking for a 3-5 meters long cable. Will it have any "loss" in transmitting anything from and to with that length?
    Thank you.
    #2275
    Quote Originally Posted by bugoys View Post
    Hi guys,
    Thank you.
    You just need a 2m cable to connect it from the dashcam to the 12V port, or better yet, directly to the car's ignition so you free up your 12V port.
    May 2013
    #2276
    Thanks for the prompt response.
    Tapping it to ignition is the best way imo, however, that car would be primarily used by my parents. My father specifically, doesn't want to touch anything on the electronics, thus using the cig port is the only way for me to install the dash cam.
    Oct 2016
    #2277
    Thank you.
    Bought this one sa Lazada, nakakabit siya sa DP200 na nasa likuran, yes, may loss siya kasi may mga oras na nagr-restart yun DP200 although bihira lang naman in my experience.
    Oct 2016
    #2278
    Side-by-side night comparison Soocoo C30 Action camera vs Transcend DP200
    Soocoo C30 ay nasa 2.5k sa lazada, while ang Transcend DP200 is nasa ~5k pataas.
    IMO, mas may details sa shadow/black parts yun Transcend, saka hindi kagad nagb-blow out ang highlights (bright parts eh nagiging white) and it is a dedicated dash cam unlike yun Soocoo na hindi talaga intended primarily for dashcam. So mas madaling mag-save/protect ng videos sa DP200.
    May FoV adjustment yun Soocoo na 170-degrees, 140-degrees, 110-degrees and 70-degrees. May 2160p resolution ang Soocoo kaya lang interpolated (2880*2160 24 fps) ito pero yun 2560x1440p 30 fps niya ay legit. Meron din itong 1080p 60 fps option.
    Pros and cons, mas mura ang Soocoo at ok naman ang quality for me pero in terms of support at warranty eh panalo si Transcend at mas madaling hanapin/mabibili ang DP200.
    May 2013
    #2279
    Quote Originally Posted by logbi77 View Post
    Thank you logbi77. Much appreciated.
    Aug 2015
    #2280
    Yo! Patulong naman bumili ako ng transcend hardwire kit, will pair it with Yi dash cam.
    Where/how do I connect the ACC red wire? Do I need to strip and splice it?
Blackbox DVR/Dashcam
