Quote Originally Posted by ronaldmb7 View Post
Nice! Sige sir pls post it. Sa ngayon hinayaan ko munang nakakalat yung wiring, weekends lang may time mangalikot e hehe!
Oo ang bagal nga sir magdownload ng vid clip...
I attached my DP520 behind the rearview mirror of my car para di masyado distracting while driving. I just make sure na there is enough space for the rear camera to have an unobstructed view of the interior:
As you can see, I allowed a little slack on the wire para pwede pa i-adjust kung lilipat ko ng konti yung camera. I tucked the rest of the wire under the interior roof upholstery. I was able to tuck it to the side pillar on the passenger side, across the seam of the pillar, into the rubber seals of the car door. Di ko na pin-icture kasi wala makikita.
Then sa baba ng side, I taped it near the floor and up to the underside of the glove compartment:
I used electrical tape para di masyado obvious. You can use double-sided tape pero nakabit ko na ng electrical tape so di ko na binago.
Then, pag-gapang ng wire sa gitna sa may hand clutch area, inakyat ko and dinikit ko along sa contours. Dito gumamit na ako ng double sided tape:
Gapang siya all the way to the cigarette lighter socket, attached using double sided tape. Sa dulo nag-iwan ulit ako ng konting slack sa wire para kung huhugutin ko ang saksakan after driving. Yung FoFo ko kasi gumagana pa rin ang socket maski nakapatay makina. Baka madiskarga.
