Page 220 of 351 FirstFirst ... 120170210216217218219220221222223224230270320 ... LastLast
Results 2,191 to 2,200 of 3510
    Sep 2016
    #2191
    Quote Originally Posted by markkevin View Post
    *junlamed
    Wow ang mura 3.2k lang english version na..
    Sent from my Starmobile PLAY Click using Tsikot Forums mobile app
    China version yan na pinalitan ng international firmware. You can find a step by step guide in Youtube. Malamang the seller did the steps himself. I think that's good service. At least the seller can confirm it works after changing the firmware, or he wouldn't ship a defective product.
    The INT'L version is about 500 more expensive. Is it worth it? Probably not. I'd take the CN version and either request the seller to change the firmware or do it myself.
    Oct 2014
    #2192
    Aside from Transcend dp520 na dual dashcam. Ano alternative dito for outdoor front and interior?
    Also, saan usually available ang Transcend? Thanks!
    Sep 2016
    #2193
    Quote Originally Posted by david_wong View Post
    Attachment 33958
    Please read carefully. This is just an installation kit. If your cam does not have built in Power Discharged Prevention features, it will drain your car battery after continuous on and prolong parking (subject to the performance of your car battery)
    Find a device like Power Magic Pro, BlackBox UPS T-Power Plus or new BlackVue B112 that can give you continuous recording and protects your car battery being drained (duration of use subject to the car battery performance and the Power Pack Battery Performance)
    Thank you
    Thank you sir for the heads up and suggestions. I was planning to tap it on the accessories slot so the cam would only turn on when the car is switched on. Just wanted a clean install. Would the cam still consume power though even if the car is turned off, even if I were to tap it on the accessories slot only?
    #2194
    I'm now considering changing my dashcam to one with dual camera because of this video.
    Facebook Video
    #2195
    Facebook Video
    Kaya I told my wife once may ganyan na incident or ma-apprehend siya ipihit agad yung cam facing the window of driver seat
    #2196
    Yan din sabi ko sa Wife ko. Although sabi ko pag may huli, may commotion man o wala, tutok nya kagad sa side window Tapat sa enforcer or who ever approaches her on the side.
    although kahit ako nakakalimutan ko ipihit.
    Oct 2009
    #2197
    Quote Originally Posted by wewoy_romero View Post
    do you keep the lcd of your dashcam turned on all the time? i set mine to turn off after 1 minute. just enough time for me to see that it turned on automatically with the ignition and tama ang pagkakatutok ng lens. after it turns off, i just have the led status tell me if it is recording or if something is wrong.
    dami ko kasi nakakasabay sa kalye na parang naka-permanently on na ata yung lcd screen ng dashcam nila.
    pros and cons?
    wala kwenta, just adding unnecessary heat to the hardware. di mo naman tinitingan ug screen habang nag drive at may flashing led notification naman yung mga maganda na dashcam pag nag rerecord. minsan yung ibang model ay nag beep pag hindi nakarecord for whatever reason. utak kase ng mga pinoy puro pa pogi kaya naka on.
    Sep 2016
    #2198
    tama ka sir danny, pagkita ko palang ng box alam ko na Chinese version, actually binigay ng 3,000 flat hehe, naka discount pa ng 200. ok lang din naman sakin kahit flashed into English version lang, ang kaso siya kaya nagflash? e nakasealed e parang factory sealed. tapos ok din ung red tab walang damage or tear e tight fitted siya. ginawa ko munang action cam sinubukan ko sa kalye, sinaksak ko sa powerbank, ayun ok ang recording malinaw.. fisheye effect nga lang hehe.
    pero sure chinese version eto kasi suction tip and 2 usb slot ang car charger e.
    Feb 2016
    #2199
    Quote Originally Posted by DannyJr View Post
    Ahh kaya pala mura.. Sa akin kasi chinese ver 3.5K bili ko plus shipping fee pa. Inupgrade ko na din to sa english ver. Hehe sulit nga ang ch ver kung marunong mag palit ng fw.
    Aug 2014
    #2200
    Question mga Sir. I have a Transcend DP520, safe bang iwan yun nang naka plug sa 12Volt socket magdamag? Hindi ba risky sa electricity ng sasakyan or baka ma discharge yung battery? Maraming salamat sa sasagot hehe.
Blackbox DVR/Dashcam
