Page 104 of 176 FirstFirst ... 45494100101102103104105106107108114154 ... LastLast
Results 2,061 to 2,080 of 3510
    Jun 2012
    #2061
    *CNS, you can also save a certain file manually by pressing a few buttons there. I will go down later so i can share it with you. I have been using DP220 for almost a year now but haven't used all its features.
    Btw, magkano bili mo? Igot mine for 5k before sa Megamall
    Mura nyan ah. Akala ko mura na kuha ko ng dp200 for 5k rin
    Sent from my SM-N930F using Tapatalk
    #2062
    Quote Originally Posted by dct View Post
    Emergency record rin. Just like recording pag nabangga. Pero di nya kailangan matrigger g sensor. Pindutin mo lang yan
    Okay bro copy hehe
    Mura ah! Saan yan? 7.5K bili ko tapos 100 na tip dun sa nagkabit hehe.
    Mamaya ko pa lang magagamit pag uwi.
    Sige bro pashare pag may tips ka pa.
    Salamats!
    #2063
    *bro cns
    naka-off lang ang g-sensor ko. sensitive masyado ang mga g-sensors kahit set mo sya at minimum, baka matambakan lang ang sd card mo ng protected files na hindi naman kinakailangan. 1080p kasi ang settings ko kaya malakas kumain ng memory. emergency record na lang. though accurate naman ang speed limit sensor, lane departure warning niyan. naka-set din yung frontal collision warning ko pero hindi ko pa sya nadinig na nag-warning. nasa 90kph yata kasi ang settings ko doon at wala pa naman akong na-experience na mabulaga sa distance during high way runs mula nung na-installed ko sya.
    parking mode? hindi ko pa nasubukan, naka-off lang ako. activated kasi sya thru motion sensor, gagamitin ko na lang sya kapag alanganin yung lugar na paparadahan ko.
    #2064
    Quote Originally Posted by benchman View Post
    *bro cns
    Yes naobserve ko nga, konting bumps record agad siya. Will turn it off na din tomorrow.
    Emergency record is manually pressing the red button?
    Just read the manual, kulang sa info bakit ganun? No features explained tsk tsk
    I already downloaded and installed the drivepro app, watched the recording via wifi.
    How come malabo? Or dapat download muna then watch? Or dapat ba sa pc/laptop ko ilipat at panoorin?
    How to activate the parking mode? Yan ba yung pag nagalaw/nabump yung sasakyan mag record?
    #2065
    Exposure ba dapat naka 0?
    How can you include your plate details sa video stamp? I explored it already, no options for that?
    Do you guys enable audio recording?
    Aug 2005
    #2066
    Exposure should be set to zero. -negative setting and beyond, your dc will record underexposed videos, while positive onwards will record overexposed. Zero is neutral. Sa qube A7 may option to save texts for video stamps. I ain't sure of features of other brands. I always set my dc audio ON.
    Sent from Zenfone2
    #2067
    Quote Originally Posted by leinahtan View Post
    Sent from Zenfone2
    Noted on this.
    Thanks bro!
    #2068
    emergency record; yes, press the red button lang. recording starts 10 seconds prior to the event you pressed the button then records 10 seconds more pa towards the event then saved as protected file.
    viewing thru wifi, medyo sketchie talaga sya. delayed pa. pero hindi naman sya con para sa akin dahil hindi ko naman sya ginagamit, pinurbahan ko lang.
    parking mode, browse mo lang sa settings bro. kung activated, mag-record sya kapag may na-detect na motion sa harap ng auto mo. it will record everything until the battery drains. occasional ko lang magagamit ang feature na 'to. kapag alanganin lang talaga siguro yun lugar na paparadahan ko.
    audio, naka-on na ako ngayon at the lowest settings. captured naman nya ang mga conversations kahit nasa low lang.
    this video might help you with the menu/settings;
    Oct 2015
    #2069
    Sir saan nyo nabili? Mura ha. Mas mahal pa sa Amazon.
    Feb 2005
    #2070
    Quote Originally Posted by Wh1stl3r2 View Post
    PC Worx sa Cyberzone Megamall.
    I browsed thru OLX then texted some of the sellers, meron dun na nakausap ko na willing to sell at 5k, then nag tingin ako sa Megamall, pasok ako PC Worx, tanong lang, sabi 5.5k daw, sabi ko may nag offer sa akin olx 5k, tinawag sa boss nila, pumayag naman kasi yun pala ka text ko sa OLX, sa tindahan din nila.
    Early last year pa yun. Actually, planning to buy another one, di pa lang ako nagagawi dun. Hopefully makakuha ulit ng mura or same price.
    Oct 2015
    #2071
    Thanks. Awesome price. Makadaaan nga ng Megamall. May wife has been nagging me to get this for our cars. May bad experience lang ako sa last ko na dashcam, sumama yung tint sa suction cup pagtanggal hehe. Ngayon may malaking bubble sa gitna ng tint.
    Feb 2005
    #2072
    Keep us posted, bro. Baka makuha mo ng same price or closer to that para sipagin na ako bumili at sumaglit dun.
    Oct 2013
    #2073
    Quote Originally Posted by wewoy_romero View Post
    xiaomi yi users:
    na-encounter nyo na continuous yellow led? pag recording kasi flashing yung yellow led.
    this morning medyo nakakadrive na ako ng mga 20mins when i noticed continuous yung ilaw ng yellow led instead of flashing. so tinanggal ko yung micro usb cable, waited for the dashcam to power down tapos kabit ulit. after nun, flashing na ulit siya.
    pagkapark, chineck ko yung video, nasa video yung pag-alis ko ng parking nung umaga. pero just 1 video lasting less than 3 mins (default ata 3mins per video). after nun, wala na. ang kasunod na video yung after ko na binalik yung micro usb cable. so merong video gap while continuous yung yellow led.
    i have no idea why this happened. obvious na may space pa naman sa memory card.
    looking at the manual, walang namention if hindi nagfflash yung yellow led.
    was able to replicate this error... seems like a sudden power loss and restoration will cause the recording to stop (solid yellow led)
    this happens when i detached the other usb device that i was charging, the ciglighter adapter came lose thus i have to push it in thus resulted in a sudden power loss and immediate restoration...
    Jul 2015
    #2074
    Complete accesories po ba yung kasama sa dp220? What are those included po? I was offered
    with dp220 complete accessories (32g) priced $150.00 and dp520 same price kaso suction cup and 32g lang kasama. I am not sure which one to get.
    Sent from my iPhone
    #2075
    Quote Originally Posted by makyong View Post
    Sent from my iPhone
    Mine has
    Dashcam
    Power plug
    16gb card
    Suction mount.
    BTW
    Can we buy a separate suction mount and power plug? Para pwede ilipat lipat yung cam?
    #2076
    with dp220 complete accessories (32g) priced $150.00 and dp520 same price kaso suction cup and 32g lang kasama. I am not sure which one to get.Sent from my iPhone
    what comes with the box of my dp220;
    16gb sd card
    suction mount
    car lighter 12v power adapter
    bargain na sir yung dp520 kung same price lang sila ng 220.
    ~9K++ sa malls ang 520.
    Jul 2015
    #2077
    Mine has
    Dashcam
    Power plug
    16gb card
    Suction mount.
    BTW
    Thank you Sir, btw, same question here. If yes, I think I'm gonna get the 520. Sir, san pinadaan yung cable ng dash cam mo?
    Sent from my iPhone
    #2078
    Sent from my iPhone
    mura yang 520 bro, tapos 32GB pa kasama? nice!
    Sent from my iPhone
    Ceiling inipit lang sa bungad then pagapang towards passenger side to A pillars, inipit sa weather strip going down to glove compartment to the 12V power source.
    not visible at all, kaso yun nga hindi na transferable.
    #2079
    apologies for the laziness in backreading if someone already brought this up.
    1. Need ko pa ba alisin sa power source everytime i turn off the engine?
    2. I rarely park in the open, pero siyempre hindi maiiwasan. Is it harmful for the camera if parked under the sun?
    3. Asa loob pala battery ng DP 220, any tips to prolong the camera life? do's and donts?
    Apr 2010
    #2080
    I have a Qube unit but this should apply to you also
    You do not have to fiddle with the power source everytime you turn off the engine, sa akin it automatically shuts down the cam at your desired time if wala nang power
    If tinted ka am quite sure na it can handle the elements naman, sa Qube it is easily removable so I remove it when parking anywhere besides our house
    Check mo na lang once in a while if it is indeed recording, aside sa heat and bad power supply nothing much can go wrong about cameras
Blackbox DVR/Dashcam
