BTW, standard ba ang suction/adhesive mount ng mga dash cam? Need ko kasi ng extra since palipat lipat dash cam ko between cars. Hassle kasi mag align pag nag lipat ako.
after several months napansin ko na advance na ng ilang minutes yung time sa sj4000 ko. both of them (i have 2).
Thanks, yung inorder ko from an online store ay may kasamang ibat-ibang mounts, check ko muna baka magawan pa ng paraan
Just ordered a SJ4000 wifi and an Aukey 4port 48W charger. Primarily a dash cam then action cam. Yung G1W sana kaso square-shaped yung mounts - wala akong makita online na nagbebenta ng mounts nun locally, and out of stock ngayon, sa Feb pa raw.
May nakagamit na ba sa inyo ng 64GB microsd? Wala pa akong inorder na microsd for it. Sa international forums kasi working daw ibang 64GB cards
Yung inorder ko pala, walang car chargerAnyone knows kung saang stores nagbebenta ng long micro usb cables? edit: already bought 2m cables. Sana umabot kahit ireroute sa pillars
May upcoming trips kasi ako Manila-Laoag, then Manila-Naga - eh those routes would take around 10hrs one way, kaya am looking sana if 64GB would be sufficient. Meron ako ngayon Toshiba 64GB na nasa phone ko, subukan ko muna yun.
Wow... Qube even has upcoming dashcams with newer chipsets than the already amazing A7LA50. Check out their website for specs and also sample video of the new dashcams.
https://www.qube.asia/xcam-a12-dashcam.html
Magkano yan sir? Edit: nasa kabilang page pala angbprice. Baka maging the next Mountek yan sa Tsikoteers. Plan ko kasi SJ5000 WiFi. Tumityempo lang ng malaking discount voucher from Takatack.
Unboxing a Qube X-Cam A7
Link to full album: Qube X-Cam A7 - Album on Imgur
Scanned manual: Qube X-Cam A7 Manual - Album on Imgur
Disclaimer: I do not have any association with Qube, or the OEM of the camera
Please bear with the low-res, out of focus pictures. Tsikot complains of max 7 images
Story
I was supposed to buy the SJ4000 Wifi, for the primary purpose of a dashcam, and an action cam as secondary.
Cancelled it the last minute, then bought the X-Cam A7. Sa ibang 'action' siguro kakailanganin yung SJ4000
The store
Inquired at Qube Gilmore IT center kung may stock, sabi nila meron. Pagliko ko to Aurora, may napansin akong isang Qube branch din. Pagdating ko to Gilmore ITC, walang maparkingan, so ikot ulit to their Aurora branch.
Mahirap mag park ng tsikot paakyat nung Aurora branch, di makasampa so nag free-wheeling yung rear right tire ko. After ilang maniobra, nakapasok naman.
Inside Qube:
Naka display yung A7 and A12 dash cams nila. May sample video na nakaplay.
Sabi ko gusto ko muna i-inspect yung item bago mag decide. Yung display item pwede naman kalikutin kaso gusto ko i-check yung actual new item. Medyo natagalan kumuha ng stock. After dumating ng item, may receipt na naka-ready na toinks.
Natagalan din kumuha ng panukli na 10 petots. Item was 3990
Unboxing
Package includes:
1 x camera
1 x camera holder - connects the mounts
1 x mini usb cable (data?)
1 x car charger
1 x mount suction cup
1 x mount adhesive
Car charger is 12V 1.0A mini usb. Pretty long cable and you can possibly route it behind your pillar without needing an extension or splicing
The camera holder interfaces with the camera as the mount connector. It contains a USB port for the GPS module (optional). The camera holder also has a mini-usb port for powering both the GPS module and the camera
Suction feedback is strong for the suction cup, it can rotate 180 degrees. Did not tried the double sided adhesive mount
Pansamantagal mount
Video/image quality
Wala pa akong spare na microsd. Tried my phone's Toshiba 64GB and nag write naman sa card, walang errors or anything - contrary to the manual and salesman na up to 32GB lang daw supported. Probably next week
I further "folded" the camera holder upward towards the mirror so it is lesser "bulky" as you've said - when viewed outside, yung cam na lang ang nakikita and di na sya nakakasagabal compared to my attached pic above.
If yung camera mismo yung bulky, you can get the Mini 0805, limited ka lang yata to the double sided adhesive mount it includes. Ang maganda sa Qube eh it has a physical store for warranty claims and cheaper by 500 for the same hardware
Car charger cable is long and i've already routed them myself through the A pillar. not quite perfect pero it is clean looking and ayoko magbayad ng isang shop just to hide a cable
Mas OK I think itong visible ang camera compared sa stealth setup - Kotong deterrent and anytime pwede ko turn left or right towards the passenger windows. Tanggal nga lang when parking on unknown/unsafe spots, which is madali lang when using the included camera holder
