Page 90 of 351 FirstFirst ... 4080868788899091929394100140190 ... LastLast
Results 891 to 900 of 3510
    Saw this in lazada - front and rear dashcam. Around 4k i think.
    Sep 2014
    #892
    Congrats!.
    By the way. Manual is available online.
    https://fccid.io/document.php?id=2574614
    From the official site: http://www.transcend-info.com/files/...20_EN_v1.0.pdf
    Will test mine tomorrow then buy a long USB 2 cable (I guess around 4 meters) para ma-route ko ng malinis instead sa USB charger ko.
    Aug 2006
    #893
    Quote Originally Posted by b_9904 View Post
    When I "Beta Tested" my DP220 at my elantra na may abang na USB cable at GoPro car charger, nagloloko ang Dp220. Minsan nagcha charge, minsan hindi. But works fine via bundled charger. I was able to confirm it works fine on ASUS powerbank and a better USB cable pero ang taba ng USB cable at ang laki ng fuse on both ends.
    So when I finally mount it in wifey's Montero, ginamit ko na lang ang bundled charger. Mahaba naman siya. In fact, sa likod na 12v socket nakasaksak ang charger at pinadaan ko na lang sa "kisame" para hindi kita ang cable.
    Sep 2014
    #894
    Quote Originally Posted by macstar1 View Post
    Awww... maybe if the amp matches hindi mag loloko?
    I use the 12v socket to charge my phones kasi.
    Alternative nag install ng additional 12v? Paano kaya yun?
    Sep 2014
    #895
    Agree. So the parking mode works as long as the built in the battery has power.
    The g sensor would still trigger even if it is off but the built in battery must have charge.
    Jan 2012
    #896
    why dont you just buy a car charger with 2 or 4 ports para di hassle? hehe
    saken kasi current set up ko capdase car voltage monitor, may 2 usb ports sya (1 amp and 2.1 amp).
    or try mo mag-hanap ng ganito
    i have 1 iphone charger (connected thru HU) then 3 usb ports
    pero minsan kapag may pasahero nakukulangan ng ports LOL kaya naghahanap rin ako nyan.
    btw, natry ko na sa 1 amp yung dp200 ko, wala naman problema.
    Sep 2014
    #897
    Quote Originally Posted by kimot View Post
    saken kasi current set up ko capdase car voltage monitor, may 2 usb ports sya (1 amp and 2.1 amp). 2.1amp at 1amp output.
    May cdr king ako na 2 port usb charger na sinasaksak sa 12v.
    So pwede sa usb basta same amp with the output ng stock charger. Ayun, solve hihi
    Mukhang tempting nga yan ah. Pang road trip!
    Magkano kaya yan boss?
    Video: https://youtu.be/PML9T9MWobA
    Jan 2012
    #898
    if i can remember correctly sir, 2 amps ata yung kasama charger ng dp200 ko pero yun nga sinubukan ko 1amp gumana naman ng walang problema.
    re dyan sa car charger cup holder, i don't have any idea sa price and i'm not even sure kung available yan saten.
    Feb 2007
    #899
    Official site has the version 1.0 and was wondering what's with version 1.5
    Aug 2006
    #900
    if you're going to hook it up to a powerbank, your drivepro will detect that as a power source and it will continue to record until the powerbank runs out of juice.
    Parking Mode's motion detect recording will not be triggered as long as there is continuous charge from powerbank. It will still be regular recording.
    And during my "beta test", my 10050mah ASUS powerbank still have lot of juice to power dp220 after 12 hours. So I suggest you use 64GB SDCard para di ma overwrite.
    By the way, not all powerbank support pass through charging. ASUS and XIAOMI are the cheaper brand which supports it, hirap lang maghanap ng genuine. In theory, kaya yata ni Asus na i power ang dp220 for a day ... Baka lang mag overwrite na ng old videos
Blackbox DVR/Dashcam
