Results 1,001 to 1,010 of 1387
- Sep 2016
- 4
August 6th, 2018 07:54 PM #1001
August 6th, 2018 08:42 PM #1002
Mahirap po masabi kung saan ang bang for the buck sa list nyo. Una, AFAIK walang G5R EX, only G5-R or G5-EX. Mostly ang mga projectors nilalagyan ng "R" sa dulo para malaman na retrofit yan. Pag G5 lang like yung sa 2nd choice mo nag iisip ako na oem projector yan ng Infinity G5 car. Also mahirap din mag compare lalo na if walang brand yung isang bulb and ang isa meron. And na notice ko sa dalawa mong choice is mas mahal ang stage 2 kesa stage 3 which is the baliktad ata or magkaiba na installer yan.
One thing I do know, if installed by a reputable shop ang retrofit mo, kahit yung entry level na package will be way better than any stock halogen.
Bigger lens or projector doesnt mean better light output. Kaya natatawa ako minsan sa ibang mga installer na pag nag advertise as if may effect yun sa output. Ang output ng projector ay depende sa optics, lens, ballast and bulb na ginamit not by the physical size or diameter of the projector. Isang example is between a 2.5" vs 3" na FX-R wala pinagkaiba output nyan except aesthetics and installation option para sa mga ma maliliit na headlight assembly. IMO pwede nga makipag sabayan ng output ang 2.5" FXR sa mga dambuhalang projectors like TL-R or LS460. Sa light width, cut-off sharpness and style at hotspots na lang magkakatalo ang mga yan depende kung ano gusto ng may-ari.
G5-R bolt on, G5-EX need to modify the reflector bowl. Both are not PnP.
- Sep 2016
- 4
August 6th, 2018 10:58 PM #1003
September 3rd, 2018 08:58 PM #1005
G5-EX I think is still 3 inches, but not threaded so nut n' bolt install. G5-EXL yung 3.2 inches.
- Sep 2018
- 1
September 5th, 2018 08:45 PM #1006Hi, what other hid projector is like the EvoX-R where the beam is more on length distance than width?
- May 2012
- 129
September 26th, 2018 12:16 AM #1007mukhang sisi ako kay xenon concepts
sabi rereplace yung defect na kinabit sa auto ko
2months na nakakalipas hindi parin ako mapuntahan
tsk
defect, ayaw na mag High Beam, minsan isang side lang,
wala narin sa alignment ayaw na mapihit naka baba headlights ko ngayon hindi masyado kita yun sa malayo
hindi tuloy ma enjoy yun tamang buga ng HID
September 26th, 2018 12:59 AM #1008
Probably HID controller ung sira.
Ung adjustment, di kaya nasobrahan sa pagpihit kaya bumagsak then kaya ayaw na umaangat ulit? Ung sa isa kong car ganun. Dulo na ng adjustment, pagkapihit ko, bumagsak, loose thread na. So what they did was binalik nila sa original then nilagyan ng epoxy to hold it. And more importantly, hindi ko na ginalaw adjustment hehe
- Aug 2017
- 870
September 26th, 2018 01:17 AM #1009
- May 2012
- 129
September 29th, 2018 11:16 AM #1010Hindi kaya mabisita yung lugar nya unang una, paranaque tapos fairview pako
*zechs
Mukha nga sir nasira sa pihit, hindi ko rin alam kasi hindi ko naman ginagalaw HL ko dati stock
Hassle lang kala ko 1month mababalikan kaso abutin pa ata ng matagal.
Ok parin talaga medyo malapit or may shop kahit medyo mahal hehehe lesson learn
Buti na lang I still have 9 more years to enjoy my DL before I worry about any changes.
