Page 100 of 139 FirstFirst ... 509096979899100101102103104110 ... LastLast
Results 991 to 1,000 of 1387
    Jul 2012
    #991
    Quote Originally Posted by D3nb3r View Post
    Yes the base of the led bulb fits but is the focal point of the led bulb the same? For example, a projector for d2s bulbs are designed specifically for d2s and the reflector of housing is designed for a d2s focal point or source of light. You change the focal point, you change also the output. A 1mm difference from source will be magnified on the output. Kaya yan din ang reason why you cant just install kahit anong hid or led bulbs on a reflector housing that is designed for halogens. Check the pic below.
    Yep, spot on info. But I really wish LED manufacturers design bulbs that exactly mimics how an HID dissipates.
    Mar 2012
    #992
    Quote Originally Posted by leodawesome View Post
    If you want led projectors you can get the Osram, Morimoto, Profile Performance and meron pa isa if I'm not mistaken I-led ang name. But the first 3 brands wouldnt be cheap since parang wala pa sa package ng mga retrofitter sa pinas ang mga yan as of now though may mga led projector installs na si tots ng redline.
    There was a post sa headlight junkies by Sam Colt pitting the morimoto mini d2s 4.0 against a morimoto M-led. Real world output, di sila magkalayo, The led trumps the hid sa hotspot by small margin and halos di ma differentiante ng general public yun, but the hid still beats the led when it comes to width. Speaking of width, this is just the mini d2s we are talking about there are a lot of oem spec projectors that have wider beam pattern than a mini d2s.
    I guess it will just be a matter of personal preference.
    Apr 2012
    #993
    I had the i-Lens Bi-Beam LED projectors even before TRS released them under the Profile brand.
    I also have a pair of Morimoto M-LED projectors for anyone interested.
    Nag sstock ako ng few LED projectors just in case meron talagang un ang gusto. Pero overall performance, HID parin talaga.
    Oct 2003
    #994
    Ang maganda lang naman sa LED is instant on sila hehe
    Mar 2004
    #995
    Also their longevity and very low power consumption ...
    Mar 2012
    #996
    isa sa mga disadvantages IMO sa mga led projectors nato is the cooling fans. The whole system is only as good as that cooling fan. If it shuts down or wont work for some unknown reason then you are screwed. Ang you might not know that the cooling fan is not even working anymore ang the heatsink gets so hot that it might have detrimental overheating effect on the circuit board or the led itself. If this happens masakit din sa bulsa magpalit ng buong system compare sa HID na you can just replace the bulbs, ballast, igniter or projector kung saan man sa kanila ang may sira. But if you have deep pockets then replacing the led projector assembly wont be an issue
    Oct 2003
    #997
    Mas priority ko ung naninilaw kong headlights haha dapat palitan ko ng brand new.
    Iniisip ko doon sa fd namin, naka stock HID siya eh. Kung papalitan ko ng brand new headlights, pwede kong bilhin ung non-hid headlights (1.8v or s) kasi i-retrofit naman after. Nagpe-peel off ung clear coat nung headlights nun ngayon eh and ung usual "sunog" part doon sa upper part ng headlight.
    Jul 2012
    #998
    Quote Originally Posted by zechs View Post
    Thus, no need for a separate fused wiring relay.
    Sep 2016
    #999
    Just read through the pages here. Still confused on which setup is better
    G5R EX
    NHK D2S Bulb
    NHK Ballast
    Stage 3 package at 15k
    VS
    G5
    D2S Bulb (not sure of brand)
    HLX Ballast
    Stage 2 package 20k
    Which do you think is bang for the buck?
    Oct 2003
    #1000
    G5R EX di ata plug and play. Nut and bolt method un. Someone correct me if I am wrong. Cant remember na. And also malaki ata ung G5r EX eh.
Planning on getting an HID retrofit
