Results 711 to 720 of 2382
May 9th, 2011 10:41 PM #714
Drove up to Baguio last night. Left Manila at 12 am and reached Baguio at 4pm. Drove thru heavy rains and fog. My FXR's cut thru them like a light sabre
. The yellow fogs and hi beams also helped a lot.
Thanks SG for the suggestion
Sobrang worth it ng upgrade by garyq.
- Dec 2002
- 2,335
May 9th, 2011 11:12 PM #715
May 15th, 2011 01:07 AM #716
Sir gary I remembered may pinost kayo dito regarding sa pagpapa-LED nung lights nung instrument panels (speedometer, tach). Gumagawa pa rin po ba kayo nun? If yes pa PM naman po quote for Civic EK.
Thanks!
May 15th, 2011 01:20 AM #717
Guys tanong lang po pag naka retro fit hid projectors ka hi and low hid na po ba ? kgaya ng sa honda jazz kasi ang alam ko lang H4 gamit ata ng jazz dba single bulb lang po? TIA
e2 po yung pic galing kay sir NighthawkGT
tsaka Hi/low po
- Dec 2002
- 2,335
May 15th, 2011 08:51 AM #718mykee: done many GE and GD Jazz already. Pls see my website www.hidretrofit.net
- Dec 2002
- 2,335
May 15th, 2011 11:25 AM #720This is a bixenon setup meaning you get a LO and HI output. For OEM spec projectors, you actually get just one output level of the bulb. At LO naka MAX na yung output nung bulb and what raises the cutoff is a shield that gets lowered down by a pull solenoid when you flick the HI switch. This is totally different from the H4 telescopic bulbs na plug and play.
Having problems posting images as well.
Problems with viewing Tsikot on non-Chromium...
