Ang Philips X-Treme Power bulbs eh mas mahal diba ?
Anyways, ano ba recommended kapag ganyan ? H7 ?
Ano ba katumbas sa HID na 6k ?
[SIZE=5]yung sa akin kasi sir H4, xtreme bilihin ko para sa advie ko sir... mahal nga sya sir pero i xpect na maganda naman kasi mahal sir...[/SIZE]
sir, yung all weather ba na yan is kakulay lang nung stock but its a lot brighter? or is it the all weather that is a bright yellow in color? and did you use ceramic sockets?
ang worry ko lang kasi for the higher wattage eh baka in the long run mas mabilis iitim yung headlight lens because of the heat that it produces...
but can anyone enlighten me on this one? if its true or not...![]()
generally, if you use higher wattages, you will need to upgrade to ceramic sockets...
the higher heat produced by the bulb can melt the original sockets (or yung reflectors, kung plastic), as well as blacken the reflectors and glass
the thing about the xtreme power and NB is they use stock wattages
*SQ :: Yung Osram All Weather real na 100/80 watts eh kailangan ng ceramic socket ?
Diba nasa 200 petot lang ang ceramic socket o mas mahal ?
Mag nnight breakers na lang siguro ako para di ko na kailangan magpalit ng socket, kasi ang gusto ko lang naman eh mas maliwanag sa stock na bulbs ( mas maliwanag naman ang osram nb sa stock diba ? ) and definitely mas maliwanag sa sw bulbs ko ngayon, which I believe is made in ....
sa maspro ako bibili ng osram nb. libre naman install dun diba ? para di na ko magDIY.![]()
nvidi :: ang alam ko pa lang na advantage ng nb eh cheaper at it gives more light than na philips xtreme
loco :: bro, san ka magpapakabit ? ako baka sa maspro nalang
tnx sir...
sa philips xtreme na lang ako, yun na talaga plan ko dati pa sir...
die hard ako sa philips...lol
Nakakadismaya naman kung 2 years lang ang life ng NB at XP.....
9606:hippie:
Kung pwede, share naman kayo ng pics ng tapon ng ilaw ng XP and/or ng NB.
thanks.![]()
baka dun na din sa maspro....kasi nakakatakot bumili sa private seller eh..mamaya di umilaw tapos inde mo na mahagilap hehe...
nga pala check mo toh...nakakatemp din...hehe
http://www.sulit.com.ph/index.php/vi...eadlight+Bulb+
loco :: Yoko na niyan. If ever I`ll go with SW's again, it`ll be HID na. Nadala na ako sa SW's, yung japan/chinese/korean brand na nabili ko eh ang baba ng low-beam ... talagang LOW!Napaalign ko na, ganun pa din.
lintek, sayang 600php ko. Hehehehe
