Page 14 of 32 FirstFirst ... 410111213141516171824 ... LastLast
Results 261 to 280 of 637
    #261
    Pag naka low beams, kahit with fog lamps, kita mo na mayroong horizontal cut off. So hindi nakakasilaw. I am assuming na hindi binago ang aiming ng HL.
    ganda nga ng cutoff kitang-kita don sa low beam. parang gusto ko na nito. hehe
    Aug 2005
    #262
    Assuming na mayroong available para sa car mo, puwedeng puwede. Hindi kasi lahat ng HL bulbs mayroon sa Philips xtreme.
    Philips xtreme din ang gamit ko. :D
    Dec 2007
    #263
    Quote Originally Posted by suysuy View Post
    btw, the first pix is only the foglights. the rest is with fogs and h4 extreme
    Wait, don't you mean the first pic has only the HEADLights switched on, instead of foglights?
    Aug 2005
    #264
    The first pic, fog lamps lang. no HL. mayroong horizontal cut off kaso nopt very sharp.
    2nd pic is fogs and HL at dim. see the _/_/ cutoffs
    3rd is fogs with bright HL
    Mar 2007
    #265
    popost ako ulit ng images para makita niyo gaano kaganda ang cut off. meron kasi kaming kapitbahay puti ang wall hehe. perfect place haha
    #266
    Quote Originally Posted by woohoo View Post
    Salamat sa pag-post...
    Pero kawawa naman ang makakasalubong mo... mangangailangan pa ng shades... at mabibilis na kamay (para mabilis maisuot ang shades)
    judging from the pic, the cutoff looks clean. the leaves on the shade area still looks dark enough.
    basta hindi lang tamaan yung liwanag sa mukha ng incoming motorist.
    Mar 2007
    #267
    sayang mas maganda sana kuha ko kung hindi ko katabi crv ng mom ko hehe. yung right beam sa poste tumama eh. bukas try ko park sa center hehehhe
    Dec 2007
    #268
    I know that's what he said, but the comparison doesn't really give justice to the old lamps, then, does it?
    Mar 2007
    #269
    what do you mean? hehe
    Dec 2007
    #270
    I mean, you should also present similar pictures using the old bulbs, para may direct comparison talaga.
    Like the ones I took here: http://tsikot.yehey.com/forums/showp...&postcount=223
    Mar 2007
    #271
    ahhhh yes. maybe later ill post it hehe. thanks
    Dec 2007
    #272
    We will be waiting, bro... :smiley:
    Mar 2007
    #273
    As Promised
    Stock is Osram 60w/55w vs Philips XP 60w/55w
    Interesting! What a difference. Take note of the posts!
    Dec 2007
    #274
    As Promised
    Mukhang mas maliwanag nang kaunti, pero mas mababa ang coverage ng XP vs. stock...
    Thanks.
    #275
    very nice post Bai!
    tama si woohoo, did you move the ride between switching?
    or it is possible that it's the Camera Auto Iso setting. it sets to accept more light on the lens when you took the osram/darker shot. and accepts lesser light when it was time for PhilipsX/brighter shot.
    or baka it's the design to eleminate a possible glare? para iwas bilis suot ng shades sa incoming motorists.
    Mar 2007
    #276
    same shutter aperture exposure and iso settings. car was not moved. i closed the gates when i changed the bulbs.
    mas wide ang tapon ng xp. notice the posts.
    grabe ang high beam, talagang centro. at mas concentrated.
    yung stock medyo ayaw ko ang cutoff. medyo sabog. yung xp talagang clean na clean
    notice the tree? cant be seen with stock. but with xp, you can see it.
    nevertheless, xp's are way brighter and whiter. mas maliwanag pa siya sa 100/90 range power white ko. galing kasi ako sa 100/90
    #277
    laki talaga difference sa stock IMO di talaga match yan dahil stock osram against philips x-treme power bulbs
    mas maganda kung osram nightbreaker vs that x-treme power or
    silverstar sabay sa visionplus.
    Mar 2007
    #278
    sabi ng karamihan mas puti ang night kesa xp. tsaka mas pinipili nila ang xp. despite whiter ang nightbreaker, sacrifice daw kaunti ang light ng night pag ulan because of the little blue tint that makes it a lil bit whiter
    Mar 2007
    #279
    its best seen in personal. ^_^
    #280
    sa bagay, preference ulit ng may ari. in my case meron naman akong 85/80W all season also from osram kaya mas preferred ko naman nightbreaker na mas puti kapag hindi na tag ulan wag lang HID look na useless
Anyone Tried Philips X-Treme Power Bulbs?
