*arnarn
pwede as long same yung size niya. usually H11 para sa foglamps.
*arnarn
Good day po,
Sayang naman wala pang mga stock ng xp (H4). as i've asked meron osram all weather na 60/55w din (roadstar) *550ea, (allweather-meron din po ata 85/80w), while their NB is at 1.4k, H4 po ito.
has anybody tried na po yung all weather na 85/80w and how it does, at this wattage, kelangan na po ba mag bago electricals (wires, ceramic,etc) may nabasa din ako na ok pa at this wattage, tama po ba?
sa mga NB users, medyo maulan po lately, kamusta naman po ang bato ng ilaw. i'm also planning to change headlight bulb. preferred ko sana xp kaso ala stock ... pero yung ok din po sana sa tag-ulan.
Thanks!
kay c3 4x4 may xp, bought 1 last saturday 1.5k. sa banawe nasa 2k bentahan. mas ok xp sa rain.
Good day sirs,
as i have observed here is a list of the pros and cons of xp (regular wattage) and of higher wattage bulbs ...pa add na lang po if may dagdag kayo
Advantages of philips xp
- Philips xp is brighter than stock
- Philips xp doesnt void warranty (for new cars)
- Its better on rainy condition due to its stock-ish color (not that white than others: nb) (as per other users)
- easy on the battery (regular consumption than higher watt bulbs)
- focus of light (more focused and intense than osram nb as per picture comparisons of other threads) therefore, could probably project light farther. (than 'scattered')
However, for those who are out of warranty or older cars, there are brighter bulbs but... (higher wattage -hw)
- for hw, need to re-configure sockets, connections, groundings, etc
- for hw, might be straneous(?) for the battery (needs more charging cycle than use of stock wattage)
- for hw with enhance of electircal, will void warranty for new cars
- hw might damage/darken headlight casings
- for osram nb, throw of light is/myt be shorter than xp
but also, it will still depend on your headlight/reflectors
I was able to buy at c3, philips xp. I chose it over other brands (although i could try higher wattages for the car is out of warranty) because (1) of its stock wattage will hopefully be good to my battery and (2) good on rain, than white-ish bulbs. i'm hoping it will be easy on the operation side (battery) and that it will last long.
other options:
higher wattage all-weather: as i was buying there another customer bought narva all-weather 100/90w, they tested both xp and the higher wattage narva and i believe narva is brighter, but thats comparing orange and apples. I would like to try an 85/80w all weather if i have the resources, soon.
btw po, san po pwedeng magpa align ng headlight? thanks po.![]()
actually, gusto ko po manual alignment although I haven't found the screws/adjustments for the headlight of lynx 01 model. i saw a step by step but its for a civic.
anybody who knows of aligning ford lynx headlight?
try ko na lang cgro tanggalin buong headlight assy para mabusisi. thanks.
try asking sa ford club philippines or pag nag pa service ka ask mo lang.
You really don't need to take off the whole headlight to look for it.
Yun sa civic, try mo hanapin yun similar part where you can slot a screwdriver sa lynx mo.
San san pa kaya meron stocks nito? At saan po banda yung shop na Blade?
Thanks
meron pa bang available na hb4 x-treme sa Roadstar Alabang? how much?
is this brigther compared sa narva all-weather (stock wattage)?
Hi Guys
Been viewing for some time now but had to register when I saw this post
Sorry had to make this post can't resist anything when it comes to car lighting is my job I work for a UK company who ship worldwide free .
Checkout this link below it will really help.Its the latest most comprehensive bulb test worldwide
http://www.autoexpress.co.uk/products/
James ..
Merong sale ngayong ng power xtreme bulbs sa Perfect Circle at P1000 lang per set, until supply last lang daw.... available ang HB4..... last week nandun lang ako... I installed Philips Crystal Vision... kasi mas maputi buga nya sa Xtreme.... although mas malayo ang buga ng Xtreme... same price din ang Crystal Vision at P1000, I ended up changing both the HB4 and HB3, kasi sale e...dati nasa P1700 sya... sa ibang shops sa banawe P1700 din ang price
