Results 91 to 100 of 333
April 12th, 2005 04:28 PM #91
Sir ghosthunter, hindi lang po kasi yung mixture ang iniisip ko..kasi panu makakatulong ang acetone sa pag save ng gasoline...ang combustion is an oxidation process..ang acetone itself can not be oxidized anymore kasi po un na yung oxidized state nya moreover, it is highly volatile...kaya isip ko po wlang effect...sbi pa nga ng kapwa chemist ko baka ma-accerelate pa ng acetone ang combustion ng gasoline imbis na makasave...
yung magtest ng acetone sa sasakyan, i think you should consult a chemical engineer..chemist lang kasi ako hindi ko alam tamang ratio ng gasoline sa acetone baka maka-apekto yan sa makina mo...saka yung acetone ata dapat industrial grade..iba yung nabibili sa drugstore eh...
April 12th, 2005 06:01 PM #92
bluegirl,
it looks like you didn't read the links at the beginning of the thread.
the acetone does not accelerate combustion of the gasoline. it also does not add energy since there's so little of it (3 OUNCES or about 80 GRAMS PER 10 GALLONS OF FUEL). the acetone is (supposed) to make the gasoline easier to atomize by reducing its surface tension or whatever...
anyway bosero, i'm pretty sure nothing will happen. the acetone is so minute in quantity. i bet if you added ONE LITER of water to your gas tank it wouldn't hurt your engine (it would cause misfiring though). But we're only talking about a MINUTE quantity of acetone. Plus, unlike water, acetone is combustible so it can be used as fuel.
April 12th, 2005 06:02 PM #93
Originally Posted by BlueGirl
The point of lowering the surface tension of gasoline is to aid in its atomization when the fuel injectors spray it into your engine cylinders.
This has already been discussed on this thread.
Here's the ratio we are adding to cars: 60mL of acetone to 40 Liters of gasoline.
saka yung acetone ata dapat industrial grade..iba yung nabibili sa drugstore eh...Last edited by ghosthunter; April 12th, 2005 at 06:06 PM.
April 12th, 2005 06:12 PM #94
Originally Posted by BOSERO
I am willing to experiment and post results as well. I just need some help in verifying and confirming the correct amount of acetone to use.
I have a 95 L tank, so this means I need to add 142.25mL (round off to 142mL) of pure acetone. Is this correct (my math is messed up since I am so excited to try it out)?
I bought acetone from Watson's. Acentone is repacked by CIRIMAR Labs. and indicates Formulation: each 100mL contains 100% acetone. I bought a 120mL and a 60mL bottle. I am assuming that it is indeed 100% pure. Please stop me from proceeding with experiment if my assumption on acetone purity is wrong. I also have a graduated cylinder. Thanks.
btw, I hope that graduated cylinder is glass and not plastic.
I am ready to put the acetone in my tank and fill up my tank as soon as you verify and confirm that I am doing it properly.
My friend who has a 1997 Suzuki Vitara is also going to try this experiment with me.
Thank you.Last edited by ghosthunter; April 12th, 2005 at 06:15 PM.
- Sep 2003
- 109
April 12th, 2005 06:17 PM #95I think this link might help in the explanation of how acetone helps in the combustion process. Its a group of engineers talking about acetone-gasoline mix.
http://www.eng-tips.com/viewthread.c...=119611&page=1
Ghosthunter,
60ml per 40L is roughly equivalent to 2.02 ounces / 10 gallons. According to the graph in the link provided in the beginning of thread, best results are obtained at 2.5 ounces (74mL) to 3 ounces (89mL) / 10 gallons (38L) of fuel.
What is the reason why you are starting at the 60mL acetone / 40L fuel instead of 74mL acetone / 38L fuel mixture ratio? Is this for the sake of experimenting with low ratioss than work your way up to higher concentrations?
April 12th, 2005 06:34 PM #96
based on the graph data, the gains in fuel milage is realized between 2 and 3 oz of acetone. I assumed using 2 oz for the test simply to verify the gains while trying to minimize the cost to attain those gains. A simple cost vs benefit decision. Not to mention, a 120mL bottle is enough to two doses. :D
- Sep 2003
- 109
April 12th, 2005 06:51 PM #97Ghosthunter,
Ok on the 60mL acetone / 40L fuel.
I will go ahead and try a higher mixture of 2.5 ounces (78mL) / 10gallons (38L) of fuel just for the sake of variety in experiments. I will start today.
Will also post results after a week (and partial results within a few days.)
My friend with the Vitara will try the 60ml/40L fuel today. I will also post his results here.
Happy experimenting to us all. Hope all our vehicles will still be ok after this! hahahaha!
Yes. I used a glass graduated cylinder. Can the acetone be stored in a plastic bottle or does it have to be stored in a glass bottle? It came it a plastic bottle at Watsons.
April 12th, 2005 07:04 PM #98
April 13th, 2005 02:29 AM #99
sir ghosthunter,
what do you think will happen if you put in less than 60ml of acetone? let's say 40-50ml? kasi i wanna try this too pero medyo natatakot ako eh. so i'll try to put in around 40ml lang muna.
April 13th, 2005 08:04 AM #100
you will get "some" gains. you can base it on the graph below.
as you can see, gains peak at 2 to 3 oz of acetone.
1oz = 29mL
I use imgur.com. Upload the picture there, then get share links, choose bbcode and paste here.
Mineral , semi synthetic or fully synthetic?
