Results 2,811 to 2,820 of 4200
- Jul 2008
- 102
October 21st, 2008 12:23 AM #2811How long since you last used your Petrol System? Either your petrol injectors are clogged or the fuel on your car is already stale (Panis na):o lets hope its the latter. This happened to me as well are you running on an SGI system? Dont forget to use your Petrol system once in a while to avoid this from happening.
- Jul 2008
- 102
October 21st, 2008 12:27 AM #2812Internal Toroidal or External? What i mean is the standard multivalves for cylindrical tanks. you should make sure that your tanks flange where you install your multivalve is inclined 30 degrees. you can check by placing a level sensor or meter on the gas box of the multivalve it should read 30 degrees. for your toroidal tank i think it is already 30 degrees so you dont have a problem with this.
- Aug 2007
- 68
October 21st, 2008 09:34 AM #2813LPG Gurus
Normal po ba na half ang tank meter gauge sa tank ko pero sa dashboard red na ung light di po ba dapat same reading sa tank & dash side ?
October 21st, 2008 09:38 AM #2814
October 21st, 2008 09:39 AM #2815
- May 2008
- 61
October 21st, 2008 12:51 PM #2816*paololorenzo, revo ang ride mo right? Pwede malamang FC mo for gas and LPG both for city and highway drives? Paki indicate na din kung m/t or a/t at kung anong variant ng revo. Thanks.
Sakin din dati naging rough na yung ride when I'm using petrol. Culprit might be stale gas since my fuel in the tank has been there for almost 3 mos which was initially full. Inubos ko nalang yung natitira and refueled again. Now my car runs well again both on petrol and LPG.
- Oct 2008
- 4
October 21st, 2008 09:15 PM #2817Hello guys,
I'm new here. I would like to ask your suggestion. I'm converting my 2008 NISSAN SENTRA GX to LPG.... been scouting for best deal from LPG installer here in our area (Tandang Sora/Mindanao Ave.). Already asked quotation for SGI system from Manila Autogas and ECONOGAS(cheaper by 5K). Can you help me make my decision.
October 21st, 2008 09:45 PM #2818
- May 2008
- 1
October 21st, 2008 10:53 PM #2819
I had my Honda Accord 2006 2.4L done here in Econogas - Cebu. So far so good. I feels and runs the same as gasoline. Fuel consumption is almost the same with gasoline. Econogas also gives very good aftermarket service. I'm so glad to have my car enhanced with a Voltron SGI System from Econogas. Thanks to Ruben, their technical chief.
October 21st, 2008 11:54 PM #2820
You can try checking this out: (click the link below)
http://tsikot.yehey.com/forums/showthread.php?t=51318
if all we are interested in are fuel versus electricity expenses, someone must already have made...
electric powered cars
