Results 1 to 20 of 4201
    May 2008
    Quote Originally Posted by gregorioong View Post
    Hello guys,
    I'm new here. I would like to ask your suggestion. I'm converting my 2008 NISSAN SENTRA GX to LPG.... been scouting for best deal from LPG installer here in our area (Tandang Sora/Mindanao Ave.). Already asked quotation for SGI system from Manila Autogas and ECONOGAS(cheaper by 5K). Can you help me make my decision.
    I had my Honda Accord 2006 2.4L done here in Econogas - Cebu. So far so good. I feels and runs the same as gasoline. Fuel consumption is almost the same with gasoline. Econogas also gives very good aftermarket service. I'm so glad to have my car enhanced with a Voltron SGI System from Econogas. Thanks to Ruben, their technical chief.
    Oct 2008
    Quote Originally Posted by emematillo View Post
    Thanks a lot Sir. It helps me a lot in making my choice of LPG installer.
    Quote Originally Posted by quan2boy View Post
    Just to share...for those of you, like me, who chose to locate your LPG filler discreetly beside your fuel filler, you may want to check if water leaks into your trunk. The past weeks have been raining and I discovered water inside my trunk. After investigation, I discovered that rain water seeps into the trunk through the gap around the LPG filler. To remedy this, I placed silicone around the LPG filler to seal it. So far, so good.
    You may want to check your trunks as well. Baka pagsimulaan pa ng kalawang...
    Cheers!
    I tried to attach a picture of my LPG filler with the silicone applied but it did not work the first time. So here it is again. Hope it works. You will see the silicone around the LPG filler to cover the gaps and prevent water from seeping into the trunk.
    Ok guys. Forgive me. Please bear with me. This is the third time I'm trying to post the same image.
    Apparently, Tsikot Gallery was under maintenance the past couple of days so that could be the reason why I'm having difficulty posting this very simple picture.
    Hope it works this time. Otherwise, I could really be doing something stupid...
    nag cut pa pala ng metal part for the lpg filler. yung sa akin sa ilalim ng bumper less worries for water going into the trunk ang problema lang hirap ng konti ang mga attendant dahil kailangan lumuhod to connect the pump nozzle. thanks for sharing sir.
Auto-LPG Conversion Thread
