Results 2,601 to 2,610 of 4200
September 1st, 2008 09:06 PM #2601
[SIZE=2]Thanks so much straker and blueVespa!!!
To Straker: What i read on this thread still confuses because i have not seen the real thing yet. There are some things mentioned in this thread i just don't understand yet.
To BlueVespa: Where is Greengas located? Approximately how much did you spend for the conversion? What kind of body modifications will they do with fitting in a toroidal tank? What is the capacity of the cylindrical tank you installed on your crv? How long will the conversion be done? dami tanong hope you could answer. thanks so much in advance!!
[/SIZE]
- Mar 2007
- 425
September 1st, 2008 09:32 PM #2602
September 1st, 2008 10:15 PM #2603
- Aug 2008
- 8
September 2nd, 2008 09:50 AM #2604My CR-V is a Gen1 so the toroidal tank couldn't fit under the picnic table without having to cut away / bend a portion of the sheet metal. I think it fits in a Gen2.
Greengas is inside the Velco LPG gas station along Mindanao Avenue across Veterans Hospital. I suggest you go there.
I paid P40k for the SGI system with a 40l tank, although I think Sharon has increased her prices.Conversion took 5 days because I initially wanted a toroidal tank and could not make up my mind about the cylindrical tank right away.
I don't know if it helped that I was there when the system was tuned, but we did an actual road test / tweaking (with my "normal" driving style) with the laptop connected to the ECU.
Hope this helps.
BANNED BANNED BANNED
- Aug 2008
- 57
September 2nd, 2008 11:53 AM #2605What LPG kits locally available work with the latest Subaru Forester 2.5 Turbo?
September 2nd, 2008 12:29 PM #2606
You'll possibly need a mid-range kit, the ones being sold for 3 liter engines and higher. You can also get the EconoGas VOGAS kit, which does real-time mixing of LPG and gasoline... so you can run 100% LPG at low rpms but still have punch at higher rpms, with gasoline off-setting the possible lack of flow from the LPG injectors.
You can try to go to Speedlab and have them install Greenfuel's 3 liter and up SGI kit... (the one for engines up to 2.5 liters will definitely not work for your engine)... they can provide on-the-spot tuning options (which I mentioned a few pages back) which will help your car run right on LPG.
And they're aching to do a Turbo-LPG conversion... there's a possibility that, with the right tuning, LPG will give you more power than gasoline, due to the better resistance to knock with ignition advance at high boost.
- Aug 2007
- 35
September 3rd, 2008 09:44 AM #2607
the branch in hi-way 54 is just the office of our korean representative. Installation is done here at my shop in Vito cruz makati. near Shopwise P.tamo.
For the tank, no need to use the donut tank, I cna show you pictures of how it can be done unis cylindrical tanks.
For economical reasons and I would suggest a close-loop.
But our SGI system will be available by end of this month (according to our principals).
- Mar 2007
- 425
September 3rd, 2008 07:46 PM #2608
- Mar 2007
- 425
September 3rd, 2008 08:04 PM #2609Is it wise for a car owner to turn his car from petrol to a purely LPG? And use the car's existing tank and fuel lines exclusively for LPG and plug in the heater, vaporiser and other gadgets between the fuel line and the engine?
- Jul 2008
- 102
September 3rd, 2008 09:04 PM #2610I wouldn't recommend such. Being able to switch to and from LPG to Petrol is a wiser decision since most LPG Stations are situated around the Metro and are not yet present in most Provinces. if you decide to convert your vehicle to SGI you would also need Petrol for start-up before it switches you automatically to LPG and visa versa. The Petrol lines cannot be used by LPG, it will have its separate line from the tank's multivalve going to the vaporizer via copper pipe. The Vaporizer and other gadgets are placed systematically and mapped out in your engine compartment. Hope this helps!
versus putting a celfone right next to your brain everytime you make a call?
electric powered cars
