You'll possibly need a mid-range kit, the ones being sold for 3 liter engines and higher. You can also get the EconoGas VOGAS kit, which does real-time mixing of LPG and gasoline... so you can run 100% LPG at low rpms but still have punch at higher rpms, with gasoline off-setting the possible lack of flow from the LPG injectors.
You can try to go to Speedlab and have them install Greenfuel's 3 liter and up SGI kit... (the one for engines up to 2.5 liters will definitely not work for your engine)... they can provide on-the-spot tuning options (which I mentioned a few pages back) which will help your car run right on LPG.
And they're aching to do a Turbo-LPG conversion... there's a possibility that, with the right tuning, LPG will give you more power than gasoline, due to the better resistance to knock with ignition advance at high boost.
