not sure, check if your LPG kit has the big cylinder thingie that has four hoses, two routes hot water from the radiator and back to it and two others are for the LPG.
If you do, then you'll need to drain it too at the proper intervals.
nope. EFI type LPG systems have their own injectors.does the lpg pass through the same injectors that the petrol uses?
Non-EFI type LPG systems use a carb type donut-like adapter fitted at the engine's air intake.
