On a standard feature the vehicle was able to demonstrate almost the same engine performance, that are:
1.Engine oil can be mixed with water at 200 mL per 50 kilometers which significantly improve engine performance rather than provide adverse outcome;
2.The vehicle can start/accelerate at high gear engagement without dragging nor shifting to lower gear position;
3.Engine can start even water is poured inside the carburetor; (Not demonstrated)
4.It accelerates its own momentum at 5 degrees feet pressure on the accelerator pedal there and thereafter ; Hanep, breaking the laws of physics hehe.
5.It can run at 25-30 kph or at 700 rpm at high gear position;
6.Engine temperature is only reaching 45 oC even in a hot-road temperature;
7.Adds 35% engine power and gives better performance when using only ordinary gasoline;
