Results 1 to 20 of 4201
    Quote Originally Posted by n5110 View Post
    question lang po:
    1.0 has anyone tried using resistor type plugs? if yes does it improve your lpg performance?
    2.0 how about iridium and other type of spark plug aside from the plugs recommended by OEM. may nakagamit na ba and does it also improve your lpg performance.
    reason for the question:
    im using lpg for almost 5 months now with stock plugs * 7K km running on lpg. the problem now is when the car is idling without AC, nag ddrop and RPM to the point na mag stall na yung kotse. during the first 3 months naman hinde ganito.
    as recommended by greenfuel yesterday (alvin) try to replace the plugs with resistor type or the 6pbs type. i want to check with lpg user first para malaman kung may significant impact ba ito otherwise i will stick with the stock plugs. Thanks.
    Just maintain the same type of sparkplug you are currently using and simply change to one step colder.
    From what I have been reading, platinum cold sparkplugs seems to solve sparkplug related problems.
    Sep 2006
    LPG prices keep getting higher. So the price difference between LPG and petrol keeps getting smaller. With the high cost of conversion, the ROI is getting longer. It seems it is now harder to convince other people to convert than it was a few years ago.
    It is somewhat similar to what happened between diesel and gas. Years ago, their price difference is big, but not now.
    You think that would also happen to LPG, that the price difference between LPG and gas would soon catch up to just a few pesos?
    Aug 2004
    It'll get higher, but I don't know if it'll reach diesel-gas levels (and remember, diesel here is artificially cheap due to government subsidy). LPG has diverse sources, and is not reliant upon crude oil production.
    The price inflation locally seems artificially induced. We'd been talking about the possibility of hoarding a few days ago, and lo and behold, the government has already caught at least one trader hoarding LPG canisters.
    I'm sure there will be many more to follow.
    * mile2 &GH : thanks for the advice. will replace the plugs with a step colder, check ko sa suking tindahan. update ko kayo. maraming salamat
    Curious lang ako...so dun sa mga meron real-time fuel consumption meter (e.g. Fortuner), I guess it would be interesting to see the "mileage" you're getting on the display when running on LPG??
    Aug 2006
    Quote Originally Posted by quan2boy View Post
    I have MID in Innova same with other IMV (Fortuner and Hi-Lux), the display is the same as it calculate base on the matrix of Air-fuel mix, electronic gas pedal movements, electronic throttle, cam/crank MRE sensor and emission sensors. Basically, it does not include in the matrix the gasoline tank meter as it will not give accurate reading all the time when the car is moving.
    So when on LPG mode, the MID average Km/li reading is just as normal when in petrol. I usually get a minus 1-2 average Km/li reading when on LPG.
    Quote Originally Posted by Mile2 View Post
    Hehe. Thanks Mile2. Akala ko kasi malilito yung computer kasi di nababawasan yung fuel sa tank...
    question lang po:
    just came back from greenfuel, nakita din ang problema ng kotse ko, it turns out na yung vaporizer ang may sala, after replacing with a new (?) one, nawala yung problema na rough idling. sabi ni alvin meron daw part/s sa loob ng vaporizer na madaling masira, yung kinabit niya modified na raw.
    so far hanggang makauwi ako dito sa bahay hinde erractic ang idle even if i turn off the AC. ayos na at salamat sa team greenfuel.
    ang hinde na lang ayos ngayon yung presyo ng lpg, 21.50 sa cleanfuel sucat..rollback naman jan
    Usually its the diaphram.
    due to dirty lpg kaya?
    Feb 2009
    I'm a total newbie sa auto-LPG. Where can I find an updated F.A.Q? I want to convert a SUV kasi.
    Would auto-LPG offer the same performance as unleaded? Parehong hatak, walang slowdown? Same horsepower?
    Does it harm the engine any more or less than when the car is running on unleaded?
    Low maintenance ba ito?
    Aug 2006
    Quote Originally Posted by Zoolander View Post
    Use your browser and key in the keyword "auto lpg" and you will get tons of information/FAQ from simple to more technical.
    or you can back read this thread, I'm sure all your questions in mind are answered in this thread already.
    or you can visit local installers to see how things are done on a car. See this thread also http://tsikot.yehey.com/forums/showthread.php?t=50159
    Your questions have already been answered in this thread. You might want to take the time to read through it. Your questions and others more have been answered in this thread.
    As for converting now, the current price difference of gasoline and LPG is not that big so it might not be economically feasible for you to convert to Auto-LPG unless you are doing a whole lot of kilometers in a month.
    Quote Originally Posted by smdelfin View Post
    hi smdelfin! actually the shortage is not because of hording etc. its because of Europe buying LPG now that its winter time. LPG is a by-product when you produce gasoline and diesel so i don't see it having shortage issues due to production and its prices should return to normal levels soon enough.
    Quote Originally Posted by XOOMaster View Post
    Try telling that to the senators and congressmen who have the IQ level of a worm.
    Aug 2008
    Good evening to all auto lpg users. I have been using it for 5 moths now.
    My friend said this morning that there was a news of a taxi in makati whose lpg tank blew. Please shed light on this matter. Thanks
    Aug 2008
    good evening. Please shed light on what caused the taxi in makati that is running in lpg that blew up as per bomboradyo report last feb. 2. TY
    Quote Originally Posted by denski2008 View Post
    The fire was cause by the A/C blower catching fire.
    Do you think a gasoline fueled taxi cab would do better in that same situation?
    Aug 2004
    Or a diesel powered L300? Or Ferrari?
    The driver said flames were coming out of the aircon vents. That indicates an electrical fire caused by faulty wiring or a faulty blower motor.
Auto-LPG Conversion Thread
