Mabagal ang rollback. LPG is only semi-dependent on crude oil prices, since crude oil is only one of the sources of LPG.
I don't rightly know... I've noticed that I can get a lot more LPG at Total... but I don't know if it's the weather or the pump... parang matagal bagong mag auto-cut-off.
Mabagal nga ang cut-off ng Total, madalas naiinip ako pinapatigil ko na lang kahit di pa No-Flow.
Usually Total auto LPG pumps has this valve regulator just before the filler gun, some attendants will adjust it fully open and this is the reason for overfills beyond the 80% safety limit, but when the regulator valve is positioned halfway then the NoFill will come very slow but will give you assured 80% cut-off.
SeaOil pumps don't have this regulator valve before the filler gun so it fills beyond the 80% safety limit.
