Quote Originally Posted by n5110 View Post
Hello fellow lpg users,
I had a weird electrical glitch yesterday on my way back to manila from clark, not sure if this have any connection with my lpg wirings etc. i have no electrical problems with the car.
from work i drive to nlex back to manila, made a stop over at caltex para magpahangin ng gulong, switch off my engine, after filling up my tires (less than 5 minutes) the car would not start, no lights on the dash, totally dead na parang diskargado ang baterya. i ask the attendant to push the car to the side.
i remove the battery and connected again, normally the alarm will beep one time pero this time parang paos yung tunog ng beep ng alarm. try to start wala talaga. removed/reconnected the relays sa engine bay ayaw pa din.
then i tapped the dash board underneath the steering wheel, after few minutes tried again and bumalik na ulit, nag start yung kotse na parang walang problema. not really sure what cause the electrical glitch. may naka experience na ba sa inyo ng ganito? hanggang sa makauwi ako ng las pinas wala naman akong naging problema. very weird, my first time to encounter this problem.
Something similar happened to me before but it was caused by a loose battery terminal. Simply tapping it solved the problem on the spot. When I arrived at the destination, I re-tightened the terminal connectors' bolts.
