I have tanks coming in by October for Internal 3 variants 40, 45 and 55. You can check which one suits you.
Actually LPG runs better when heated well. Our cars water system is tapped to the vaporizer for it to heat up thus turning the liquid LPG coming from the tank to Vapor LPG. This is what goes into the cars engine.
Uphills should be no problem with SGI systems since it directly injects fuel into the manifold and into the engine. I think your running too rich that's why "parang lunod yung mixture ng air and gas" Ask them to tune it up to avoid stalls.
What type of kit was installed on the Camry? Well Lambda O2 sensor connections are optional. It does help though for the ECU to recognize the mixture needed so installing it would be a plus.
My car has been installed with an LPG system since December07 and I have no O2 connection but it runs fine with no problems. So i think it boils down to the proper ECU calibration.
