Results 2,541 to 2,550 of 4200
- Aug 2008
- 24
August 21st, 2008 06:46 PM #2541It's my first time posting in this forum.
My Dad told me to research about LPG Conversion and I stumbled upon this site when a LPG convert posted the links in tipidpc.com. (This was just last week)
This is actually the first forum my dad (in his late 50's) actually read and got him interested in it. This thread actually persuaded him to go ahead with the LPG conversion in a matter of days.
We had his '96 Camry 2.2L 4Cyl converted last tuesday and picked up this afternoon. We got a chance to meet with Mike of GreenFuel. The O2 sensor wasn't installed as per Mike's recommendation and that my dad should observe it first and see how it goes. Good thing GreenFuel decided to take on the job of this specific Camry model because according to Mike the installation/drilling was a tough one.
We told Mike that we're also planning on having my Mazda 3 1.6S converted as well if the camry produces good results.
I'm thinking of having a cylindrical tank 60L installed since my line of thinking is that in case of a rear collision there will be more crumple zone before it hits the tank. I also get to refuel less to since it holds more fuel.
Would this be wise?
Or a toroidal tank be a wiser move? I was thinking the toroidal tank when hit from the rear will puncture more easily because of the donut shape..
It also as fuel capacity means I need to refuel a lot more often.
Mike also mentioned the CEL problem the Mazda 3 was known for. Is this a regular occurence? or a twice a year thing?
He mentioned it happens when it gets lean?
Can this be reset by a normal user? or only shops with computers?
what does that mean? when my lpg gas is almost empty or if I rev too much? (I drive relatively slow 80 to 100kph tops)
Sir GH, I think I saw a thread that you had a Mazda 3 converted. How's the FC? I'm ok in losing 10% in FC. I usually get 10km/L from alabang to pioneer.
I'm having 2nd thoughts because of the "kapihikan" of my Mazda 3 because of the CEL mike mentioned.
(I've read around this thread jumping around since this thread started years ago)
August 21st, 2008 07:14 PM #2542
People should post links to the tsikot.com Auto-LPG thread in other sites outside tsikot.com so those interested can find it easier. So far this is the most comprehensive auto-lpg discussion in the country.
I'm thinking of having a cylindrical tank 60L installed since my line of thinking is that in case of a rear collision there will be more crumple zone before it hits the tank. And I get to refuel less to since it hold more fuel.
Would this be wise?
Or a torodial tank be a wiser move? I was thinking the torodial tank when hit from the rear will puncture more easily because of the donut shape..
And lesser fuel capacity means I need to refuel a lot more often.
Generally I would suggest the torrodial tank because that will give you more trunk space, especially if you need to carry bulky cargo items since the Mazda3 trunk isn't as big as other cars.
The cylindrical tank does have a good aspect. The remaining fuel inside will concentrate together in the middle and you can drive near-empty more confidently than with the torrodial tank because the fuel will slosh around more and it would be harder to suck up the last few of liters of LPG from that type of tank.
As for refueling more often, it's more of a function of the either tank's capacity. So if you got a 60L torrodial tank, it would hold as much fuel as a 60L cylindrical tank.
How's the FC? I'm ok in losing 10$ in FC. I usually get 10km/L from alabang to pioneer.
Kinda hard to diagnose the problem because our Mazda3 is a busy vehicle so downtime for it is hard to schedule.
August 21st, 2008 07:57 PM #2543
August 21st, 2008 09:09 PM #2544
Have you tried using hotter rated sparkplugs than what you already have in your engine? Since your driving style sees more idling, your current sparkplugs might be too "cold" which results in fouling.
Regular hotter sparkplugs are cheaper than special iridium sparkplugs anyway.
Note to other auto-lpg users: sometimes other cars run better with colder sparkplugs. It plainly depends on the engine and your driving style/habits.
August 21st, 2008 10:44 PM #2545
It's not more of the long idling I guess, when I drove to airport at high speed last Tuesday, real hard fouling came day after it so it must be a colder spark plug to be use.
Bad thing is when I called up Denso distrubutor they would not have the colder plug this month. I'm force now to use their one grade colder Iridium. P600 x 4
Innova (1TR-FE) and Fortuner (2TR-FE) uses long reach plugs even NGK and Bosch don't have much lineup for these kind of plugs.
August 22nd, 2008 07:35 PM #2546
Thanks to this thread. Very helpful. Gave me the courage to go LPG. Had my 2002 Camry 2.2 done last Saturday at Greenfuel. Medyo may konting problems pa which I hope to fix in due course.
1. Engine check indicator lights up. I'll bring to Toyota for checkup.
2. Initially, power is almost same as gasoline but after a while (maybe 30 minutes of Edsa driving), car won't accelerate. I had to shift back to gasoline to get the power I need. I brought back to Greenfuel kanina and Ian made some adjustments (baka daw masyadong "lean"). It did improve a little pero kulang pa rin, i.e. after 30 minutes or so, medyo hirap pa rin mag-accelerate...
Thoughts?
- Mar 2007
- 425
August 22nd, 2008 10:31 PM #2547Quan2Boy,
Is your Camry using SGI?
Is the aircon on? Have you checked your air filters?
- Oct 2003
- 176
August 22nd, 2008 11:43 PM #2548Just to share.
if SGI yung kit mo then we have the same problem.
Car: 2004 mitsubishi outlander
Observations
1. Check engine lighted
2. after 30 minutes, medyo hirap umabante, kahit nakaflooring na yung gas pedal mabagal acceleration.
3. LPG fuel gauge nagloloko.
Will have it checked this coming monday afternoon.
August 22nd, 2008 11:57 PM #2549
dude, san ka nagpa convert? kasi ganyan dati ang prob ko sa adventure ko using EROOM's closed loop kit...almost all na mitsu na kino convert nila ayon kay bigfootoz e may CEL (check engine light) prob...pero naayos na ng EROOM yun ngayon, nag add pa ng isang emulator yata yun o ECU, ayun wala na, mas gumanda pa takbo...i think sakit ng mitsu talaga yan na kapag walang nasesense yung engine na walang lumalabas sa nozzle ng gasoline e umiilaw yung CEL...maganda i-coordinate ng installer mo yan sa MMC (mitsu motors) para ma-address...
__________________
passion for fashion? craving for savings?
visit MAI PASSION boutique at the fashion village * Tiendesitas
August 23rd, 2008 08:23 AM #2550
the winner is selling it :twak2: 350k daw i already messaged him haha. it's just a free car so i'm...
Bestune Pony mini EV
