Results 31 to 40 of 52
February 13th, 2006 04:10 PM #31
Sa E36 you need to replace the shocks, water pump, evaporator, tie-rod, bushings, and gaskets. And, clutch master cylinder, rear wheel bearings, hood shocks, and depending on the condition, the upholstery and re-leather the steering wheel. Mukhang pang matanda yun Merc.
- Aug 2004
- 25
February 14th, 2006 10:42 AM #32For the E34, go for the engine that has the VANOS technology already... It's a bit more expensive, but well worth it. correct me if i am wrong, but i think it's late 1992 onwards when they started incorporating this on the E34's.
i have a W124 (Estate) if you can get one of these, go for that... There's just something about the W124 estates that turns people's head around. IMO...
Tsikot Member Rank 3
- Nov 2002
- 1,985
February 15th, 2006 12:16 AM #33yes, estate seem to be more of a classy car but chicks might think you have a family already. hehe. But at least estates hold their value way better than the regular sedans or coupes.
- Aug 2004
- 25
February 15th, 2006 10:02 AM #34hahahahaha... looking at it from the other side yes, but then again, there is always the boot where you and your chick can cuddle before going home to your you know who!!! joking
going back, yup, it does hold value, a lot more...
February 15th, 2006 01:36 PM #35
well, looks like i didnt end up with either of my original choices.
got the e36 320i instead.
still need to do some repairs on it, but so far so good for a car with 40 thousand kms.
only thing bothering me about it is i only got 1 key for it. what can be done to prevent from whoever has the other key from doing any monkey business?
February 15th, 2006 01:48 PM #36
Not much other than change the tumblers itself. I suggest you visit LOM in Greenhills and ask if they can change your key combo and make you a new set of master key.
February 15th, 2006 02:49 PM #40
I think they can deactivate the old code of the keys then reprogram the key. The expensive part here is getting a new duplicate key with the transponder chip (if the 320i key needs one).
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
