Page 1 of 3 123 LastLast
Results 1 to 20 of 41
    Good day people. Im a new member and this is my 1st post.
    Gusto ko lang makahingi ng feedback from you guys as to which car between the 2 would be a better buy as a 2nd car. tnx in advance guys.
    hmmm..tough choice....
    pero sa cefiro ako.
    Oct 2005
    Cefiro Elite...2001 yan ang 1st yulon Cefiro e...dame features.
    Dec 2003
    accord ako, 2001 accord. kaya lang wala sa choices
    2001? Cefiro ako...
    May 2005
    i think the cefiro would be less expensive 2nd hand than the camry and would have the same or better features kaya cefiro na ako ..
    More parts available for the Cefiro over the old Camry as this model was more popular... if it's the Elite version with the plastic headlamps na check the electrical parts like the power windows, door locks, and antenna if they're functioning properly.
    tnx guys for the inputs. mukhang mas maraming may type sa 01 na cefiro. since out of warranty na ito, do you suggest na casa pa din pms o can you suggest a reliable outside shop that services cefiros? tnx again in advance po.
    I suggest casa, Mantrade and Commonwealth ang usual recommended ng mga taga nissan bayan... I personally go to Mantrade...
    Di naman mahal sa casa actually, esp if may sale ng parts like right now afaik may sale mga pyesa ng cefiro...
    But the camry is a good choice din, engine wise parehas lang ata sa Corona/RAV4
    Cefiro din ako. You get more stuff for your money.
    cefiro. lots of goodies like movable headlamp aim, etc... :D
    Theveed, the Camry '00 has a 2.2L engine (i dunno lang kung pareho pyesa sa 2.0 Corona and old Rav)
    You can still go to the CASA for major maintainance services (every 20,000kms usually) then go to your regular talyer for the 5,000 change oil job.
    Before you buy it make sure you have a good condition unit coz kung may sakit yan, masakit sa bulsa din (you also have to load 95 octane sa Cefiro). When you test drive, listen for any signs of "tope"/detonation, check the underchassis, check engine (under) for any leaks, observe the idling, etc.
    Aug 2004
    mmmhm... 01 Cefiro... that 2.0 V6 is still one of the best and quietest engines ever made. :D ...and the car's not bad either. :lol:
    Quote Originally Posted by vinj
    Ah ok, may nagpalinis kasi samin na '99 camry na naka 2.0 engine hehe sorry.
    Oct 2005
    yup sir Theveed, 2.0L po yung Corona at gen1 Rav4...gen2 Rav4 is still 2.0L but with VVti with a choice of 1.8L also.
    Nissan Cefiro's VQ engine is one of Ward's 10 Best engine for almost a decade running.
    Quote Originally Posted by theveed
    Na-change engine perhaps?
    They look pretty similar though (yung sa Camry na 2.2 and Corona na 2.0) if memory serves me right.
    hindi pare, stock na stock sobrang alaga... tapos 2.0 yung nakalagay sa sticker sa hood... hmm... we're talking about the camry na mukang aircon louver ang grill ha, not the current one...
    Anyway, can't go wrong with either choice, both are good family cars that have solid reputations.
    True.
    My Tito is still very happy with his '97 Camry. Our '99 Cefiro Elite was sold before to Nissan Gallery on an x-deal (with 70K+ on the odo) and up to now gamit pa rin ng isang manager nila.
    Quote Originally Posted by niky
    Resale value of Nissans are a bit lower than Toyotas...
    Aside from the brand image, the Cefiro seems to be the better car between the two.
    Ever since the boxy Camry was launched here, I always thought it looked bland and underpowered(129hp) for a 2.2 liter car.
    They look pretty similar though (yung sa Camry na 2.2 and Corona na 2.2) if memory serves me right.
    Corona 2.2? or you mean 2.0?
    I believe the Corona had a 2.0 liter engine.
    Engine model: 3S-FE
    Type: inline-4 DOHC 16-valves, EFI
    Displacement: 1998 cc
    Bore & Stroke: 86 mm X 86 mm
    Compression ratio to 1: 9.5
    Max. Output: 126 hp * 5600 rpm
    Max. Torque: 177 Nm * 4400 rpm
    Camry 2.2
    Engine model: 5S-FE
    Displacement: 2164 cc
    Bore & Stroke: 87 mm X 91 mm
    Compression ratio to 1: 9.8
    Max. Output: 129 hp * 5200 rpm
    Max. Torque: 198 Nm * 4200 rpm
    Never knew there was a Camry 2.0 here, maybe it was an imported model?
    Could it have been a Toyota Corona Premio?
    I think some of these were sold here through the gray market after Toyota replaced the Corona with the Camry in the local mid-size segment.
2001 Cefiro Elite vs 2001 Toyota Camry GXE
