Results 21 to 30 of 40
January 4th, 2013 11:38 AM #21
Naiisip ko din un kay TS. Kung palagi din naman puno ung sasakyan niya dapat retain na lang niya ung Sportivo. Naisip ko parang mapupunta sa wala yung fc pag puno lagi ung avanza saka ung APV
- Oct 2012
- 11
January 4th, 2013 04:46 PM #22Thank you for all your inputs...
Flood fording is somewhat a necessary because we are in Malanday which is very prone to floods.
The vehicle is not always full... Usually during weekends only...
One of the reason why we want to change it because its slow.
Though hindi naman po kami kaskasero sa sasakyan pero nagkaroon po kasi ng time na
emergency dahil po sa lola ko... Hirap po maka-overtake during that time so parang naisip nadin namin siyang palitan...
Nakakatakot po kasi during sa time na yun e...
Anyway idiscuss nalang po namin siguro ung point na baka mas ok talaga retain na lang po ung sportivo...
January 4th, 2013 04:57 PM #23
In that case just retain the Sportivo. The Avanza and APV aren't exactly track stars even compared to the Sportivo. They are still utility vehicles with small engines, driving dynamics and power aren't their strong points. The Sportivo will be a little cheaper to run as well.
January 4th, 2013 05:27 PM #24
January 4th, 2013 10:21 PM #26
January 8th, 2013 04:47 PM #27
TS magpalit ka na lang ng sportivo MT, sigurado pedeng pang emergency. nakakadismaya talaga un AT ng isuzu.
- - - Updated - - -
- Jan 2013
- 1
January 8th, 2013 05:44 PM #28huong dan ca cuoc tren mang
huong dan ca cuoc online
huong dan ca do bong da
huong dan ca cuoc bong da
huong dan ca do tren mang
huong dan ca do bong da online
huong dan ca do bong da tren mang
huong dan ca cuuoc bong da online
huong dan ca cuoc bong da tren mang
huong dan ca do bong da truc tuyen
huong dan ca cuoc bong da truc tuyen
huong da ca do qua mang
huong dan ca cuoc qua mang
huong dan choi danh bai an tien tren mang
cach mo tai khoan ca do online
January 8th, 2013 06:12 PM #29
If extra power is more important, just swap to a Sportivo MT.
If you're just going to get an automatic, the APV 1.6 AT is horrendously slow. Almost as bad as the Crosswind. The Avanza 1.3 AT is quick from a stop because first gear is very short, but if you're overtaking on the highway in an emergency, it has very little power.
- - - Updated - - -
January 8th, 2013 06:41 PM #30
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
