so, till kelan pwede pa paint protect? Pwede ba sya kahit 1month old na ang kotse?
di naman pala kamahalan.. Meron kayang paint na di talaga dumidikit yung putik? Parang tiles, ehehe..
yep, will always keep you guys updated. Thank you, Sir.
Anyway, Hazel got her first full tank, 58.42L of Xtra Unleaded. Grabe, 3000.45 petot! Ahaha! Anyway, I would then be able to compute the FC by my next full tank, probably next week.
Pa wheel alignment ko this week, which is free basta less than 1000kms pa.. Sayang naman..![]()
Well, di naman kelangan, pero sayang, pacheck ko lang.
Meron daw atang issues with it, medyo kumakanan daw kapag binitawan ang steering wheel. So, ayun. Sabi nila China has different roads, kaya ganun yung alignment nya.![]()
As long as it's free, get it done na, before it starts affecting your tire wear.
It's normal for cars to veer to the right on most roads, as our roads are cambered to the right, for water drainage. To check if this is an alignment problem, find a road you drift to the right on, then drive back along the same road on the left side (as long as there is no oncoming traffic) to see if the car drifts to the left. If it does, your alignment is fine. If it doesn't, or drifts more to the right than to the left, then get it aligned.
makes perfect sense. Matry nga mamaya..
The thing is, saan ko kaya gagawin to, ah tama, meron sa Clark..![]()
What do you mean po na wala na? Dun na kasi ako sa Haima Cars thread nag-uupdate.![]()
