Results 21 to 30 of 42
- Apr 2008
- 6,235
August 5th, 2013 02:22 PM #22For hardcore workhorse use with lots of off roading, I'd go with the D-Max. Wide max torque range is a boon. I believe this is also the only one among the three where you won't be feeling much of the effects of turbo lag. I've driven the 4x2 LT (IPV variant) and assuming that they have the same brake system, I'd say the brakes bite very well despite the rear drums and lack of ABS. Ride quality definitely isn't the best, though handling is quite acceptable for a truck.
If the "recreation" part is more important, you'd probably appreciate the Strada's bigger backseat and more comfortable ride in general. The power amenities are also a swaying point for me, though having them installed in the D-Max shouldn't be much of a problem. If it helps, I'd also mention that the Strada has a much heavier steering than the D-Max.
Sent from my GT-I9100 using Tapatalk 2
August 5th, 2013 02:36 PM #23
August 5th, 2013 03:01 PM #24
Our company uses several Strada GLS for the field personnel. Very capable naman off-road. Usually yung mga site na pinupuntahan ay nasa bundok.
OT: Pero come to think of it, L300 lang dati service ng aming field personnel. baka inaahon nila din ng bundok yun. LOL
- Jul 2009
- 2,618
August 5th, 2013 03:21 PM #25For company use i vote for Dmax but if you are equipping a fleet the L200 appeals also beacause aside from the advantage of having ABS they give a not-so-insubstantial discount. For one unit i inquired before less 50k so savings add up when quite quickly when more units are bought. I'm not sure though exactly how much more they can get less if you get more units.
August 5th, 2013 04:16 PM #26
How times change no? Before, families could get around using an L300 or Lite Ace with less than 100hp. Companies would use a Nissan Bida, Tamaraw or L300 FB, and okay na. Ngayon, maunahan lang ng turbocharged Evo or Subaru sa highway, or hindi makatabo ng 200kph, underpowered na daw.
Some companies (i.e. Chevron) have mandatory safety requirements for company cars (dual airbags, ABS).
August 5th, 2013 04:23 PM #27
August 5th, 2013 04:57 PM #28
- Nov 2009
- 3,507
August 5th, 2013 08:56 PM #29Strada will do the best job for this category. The Brute is kinda useless 4x4 without the LSD, i like the gray interior thou.
Doc, ayaw mo TOTL? Ganda nyan S&R vehicle.
Another option is K2700 4x4 para derecho abulance..heheLast edited by 12vdc; August 5th, 2013 at 09:05 PM.
August 5th, 2013 09:37 PM #30
Shell also mandates ABS and SRS for fleet vehicles and even personal vehicles if it will be availed through their car plan.
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
