Results 31 to 40 of 46
- May 2011
- 53
October 12th, 2011 09:25 AM #31
- May 2011
- 53
October 12th, 2011 09:28 AM #32
- Apr 2008
- 6,237
October 12th, 2011 02:43 PM #33Yes it does. I'd suggest you look for Racechip Pro or Unichip for this one. Many of our Tsikoteers here have installed these on their rides and gotten very favorable results. It gives the best results on electronically controlled, turbocharged rides though. There are plug and play versions of these chips so that they won't void the warranty of your car. So if you are looking at the Starex Limousine and Suburban ONLY, I'd suggest you get the Starex Limo and chip it for an extra 20-30 wheel horses or so.
- Jan 2008
- 4,726
- May 2011
- 53
October 13th, 2011 07:23 AM #36
It's used to get the intake air cooler, for evaporative pressure due to the water and methanol blend sprayed into the intake manifold absorving some heat from the intake air. Just like an intercooler does in a turbocharged vehicle. BTW even a turbocharger can be a good way to deal with the fuel-efficiency since it enhances the combustion efficiency...
October 13th, 2011 06:15 PM #37
sorry if i sounded a bit pessimistic on an earlier post. If your purpose is a daily-driver with all the finesse, Starex Limo would be my pick. If the purpose would be for occasional socialite events, or if you need to modify your ride as a bullet-proof transporter, Suburban would be my pick. But it's just me and I might also err.
As far as chips, I have no experience with those enhancements, so far... but i think they only work on diesel engines with crdi technology.
October 13th, 2011 08:05 PM #38
You can chip gasoline vehicles. You can "chip" anything that has an ECU.
- Dec 2003
- 131
- May 2011
- 53
October 17th, 2011 06:35 PM #40
I just imagine it's a manual especially at low speeds or while maneuvering on inclines. Nature of...
(2023) Ford Territory
