Results 71 to 80 of 85
December 29th, 2012 02:04 AM #71
Chief Ano727, we all feel the same most of the time in choosing between options, and take it that that's the beauty of having choices/ options/ alternatives from among available rivaling car brands in Philippines. It's better to have that choice in time you need it than not having at all when you need it.
Nonetheless, if PRACTICALITY still weighs more than GOOD LOOKS, the Chevy Trailblazer is still the best among the relatively cheap SUV segment. This is what i posted (an excerpt only) at TopGear Philippines in relation to testimonies from two Trailblazer owners thereat (one of them is even a BMW owner who now raves about his TB) and a Monterosport owner here at tsikot as regards to land speed versus the engine-rpm they're at when driving their respective SUVs. Take note that the land speed were calculated based on tyre specs and gearing specs, and rpm they mentioned during series of discussions.
WOW chief nicely described! Thanks sa advice re the speed of Trailblazer 2.8 Duramax running 130 kph * 2100 rpm, Mas naging kumpleto listahan ngayon ng currently-available SUV/ CUV sa Pinas, ranked from super-bagal to mas mabilis among the top-spec variants:
MITSUBISHI
Monterosport 2.5 GT-V A/T (174 hp, 350 Nm) at PhP1.71 M ---- 107 kph * 2100 rpm
Pajero 3.2 Di-D A/T (165 hp, 363 Nm) at PhP2.70 M ---- 107 kph * 2100 rpm
TOYOTA
Fortuner 3.0 D-4D A/T (163 hp, 343 Nm) at PhP1.72 M ---- 117 kph * 2100 rpm
HYUNDAI
2010-12 Santa Fe 2.2 R-eVGT A/T (197 hp, 437 Nm) at PhP1.76 M ---- 119 kph * 2100 rpm
(118.63 kph to be exact with 235/60/R18 tyres)
2013 Santa Fe 2.2 R-eVGT A/T (197 hp, 437 Nm) at PhP2.23 M ---- 119 kph * 2100 rpm
(118.93 kph with 235/55/R19 tyres)
Hyundai Tucson 2.0 R-eVGT A/T (177 hp, 392 Nm) at PhP1.72 M ---- 119 kph * 2100 rpm
(118.82 kph with 225/55/R18 tyres)
CHEVROLET
Trailblazer 2.8 Duramax A/T (180 hp, 470 Nm) at PhP1.72 M ---- 134 kph * 2100 rpm
Chief, i finally got hold of the gearing spec of the Trailblazer 2.8, just private message me if you don’t have a copy. Tama ka sa claim mo re 130 kph at 2100 rpm with the 265/60/R18 tyres.... With the 245/70/R16, on the other hand, it is speeding at 129 kph.... Ganda talaga ng Trailblazer WOW lalong matutuwa yung kaibigan ko nito na pa-order ng 2.8 this December 2012 hehe! Same thing goes for the Trailblazer 2.5, according to Mindkinetic, he's running about 127 kph at 2100 rpm.... SULIT-na-SULIT talaga ang pinaghirapang PhP1.3 M to PhP1.7 M hehe, hindi gaya nung isa haha!!!!
Obviously, the Fortuner, Santa Fe, Tucson, and Trailblazer 2.5 and 2.8 achieve better cruising speed at any one-point along the rev-range than the Monterosport.
Practicality-wise, the lesser engine-rev you make, the lesser sequential pressure combustion there is in a 4-stroke or 2-stroke cycle engine. In this case, we're talking of 4-stroke diesel engines.
Good luck!
- Apr 2011
- 540
December 29th, 2012 05:46 AM #72Do you have data on the 0-100kms acceleration on the vehicles you mentioned? Just curious on who will win in case mag drag race mga SUVs na ito, hehe.
- Apr 2011
- 540
December 29th, 2012 05:47 PM #73Last edited by bjreyesmd; December 29th, 2012 at 05:49 PM. Reason: additional info
December 29th, 2012 06:34 PM #74
Chief, that's because petrol-fed vehicles can rev way farther out compared to diesel ones. And where is the CX 9's peak horsepower located along the rev-range - is it at 6000 rpm rated at 280 hp? How about the peak torque, at 4000 rpm or 4500 rpm, rated at 367 Nm?
With the crank rotation at 6000 revs a minute granting you manually rev-out the powerband for the most hp prior to upshifting your gears just imagine how much speed rotation your crank turns the wheels at - a lot i think compared to diesel engines reving out anywhere between between 3800 rpm to 4500 rpm the most.
However, when it comes to pulling force (hauling, towing, hillclimbing, drag racing in power-sapping soft sands) be it at low. mid and high revs, the diesel feds will feast on the gasoline ones, especially the Trailblazer's rated at 470 Nm torque starting at 2000 rpm.
December 29th, 2012 09:48 PM #75
Agree, the diesel torque curve heads down when speeds/revs rise. So the cx9 should take the drag race. High torque low rev applications will be the turbo diesel's specialty.
December 30th, 2012 12:47 AM #76
Is it the 2.5 TBz or 2.8 you've pushed hard? I know how V6 gasoline ones are chief, in fact i have one, a Grand Vitara 2.7 MFi 4x4. Also, not all turbocharged petrol-feds maintain their peak torque throughout the rev-range; the Subaru Forester 2.5 turbocharged, for one, feels a bit sluggish from bottom-up when you floor the pedal, not so in the case of V6 of course, since there are more sequential up-and-down strokes to cover a cycle.
However, there are lots of diesel fed out there that maintain their peak flat torque over broad rev-range, to name a few amongst the 4-cylinder e.g., Toyota Fortuner 3.0 D-4D at 343 Nm from 1400 to 3200 rpm, 2012 Philippine-issue Fortuner 2.5 D-4D at 343 Nm from 1400 to 2400 rpm, Toyota Prado ar 410 Nm from 1600 to 3000 rpm, Philippine-issue Isuzu Alterra at 294 Nm from 1400 to 3400 rpm (same thing goes to its D-max equivalent), Thai-spec Alterra (MU-7) at 360 Nm from 1800 to 2800 rpm, new Isuzu D-max at 380 Nm from 1800 to 3000 rpm, perhaps even the Santa Fe 2.2 R-eVGT may qualify, rated at 437 Nm from 1750 rpm to 2500 rpm.... lemme also include the 5-inline Ranger 3.2 TDCi rated at 470 Nm beginning 1500 to 3000 rpm, where 95% of that 470 Nm is already tappable by 1200 rpm.... How much more the straight 6 and V6 diesel feds, coming from BMW, Mercedes-Benz, Renault-Nissan, Volkswagen, VM Motori etc?
Practicality-wise though, if that is the primary question of the thread-starter, a 4-cylinder diesel-fed SUV like the Trailblazer 2.8 that is already producing a peak 470 Nm torque at such a relatively low-rev of 2000 rpm (compared to a gas-fed, more so a V6 one) sipping way less fuel for even a higher torque. 90% of that 470 Nm on the TBz is already available by 1700 rpm. The peak torque on the TBz starts to dwindle gently down-dip past 2000 rpm, BUT it does not dive drastically as the ones you see in a Monterosport 3.2 Di-D, and or the Navara 2.5 with the high-power YD25TTi engine. It's a different story on the peak torque of the all-new Ranger 3.2 5-inline though as it is broad, and 470 Nm is 103 Nm more than the CX-9's that is seeping more fuel and needing to rev way higher. Inherently also, even commercial ones, diesel engines have higher compression ratios (16.5 to 17.9 : 1) compared to their petrol-fed counterparts/ and equivalent-displacements (around 9.5 to 10.5 : 1) that's why even at low revs they make more power and torque....
Certainly, i won't need a V6 gasoline-fed that is only producing 367 Nm torque if i'm after practicality/ functionality/ and after a responsive engine, Won't need one that is seeping way more fuel and just because by virtue of having the ability to rev way higher than diesels engines, YET producing lesser torque, they are able to achieve 277 hp. But that's just me though....
Cheers chief!
December 30th, 2012 01:05 AM #77
Nosebleed! Hehehe.
And thanks for some technical insight.
When TS chose the CX9, it's not about practicality but pure driving experience (ride, handling, safety with 6 airbags, feel of elegance and luxury inside) + a bit of frustration with Chevy dealers. TBZ no doubt is a great car as well.
December 30th, 2012 05:42 PM #78
YUP chief, the petrols need to be played at the right gear to bump up the rpm to keep them singing at their ideal powerband. Whilst prolly your Forester 2.5 XT turbocharged comes with auto-tranny/ or semi-auto gate-type, thus you can't downshift freely as you would in a cock-and-bolt style of a pure manual-tranny, just like i get out from my Suzie Grand Vitara 2.7 V6 manual transmission.... i also have had series of dirt bikes and what it means to be singing within the right rev-range to get the meat of the powerband is true in gas fed engines, and THAT IS at relatively HIGH-REVS unlike in diesel-fed engines.... LAKAS kumain ng fuel ng gas-fed hehe
Aside from the fact that the Forester 2.5 XT turbocharged makes only 320 Nm of pulling-force at 2800 rpm (not 350 Nm), that is around 236 lbf-ft. The 2.5 XT makes 226.85 bhp or 230 metric-hp at 5200 rpm, according to Subaru Motor Image Phils.
Therefore chief, it is IMPOSSIBLE to hold that 236 lbf-foot of torque from 2800 rpm all the way to 6000 rpm granting that the 2.5 XT maintains it peak horsepower from 5200 rpm to 6000 rpm. To be able to do that, its pulling-force should drop to 198.57 lbf-ft or 268.92 Nm by 6000 rpm. 320 Nm to 268.92 Nm is NOT peak flat torque chief, and the LESSER the torque gets along the way IF the peak power of 230 metric horses can't be maintained up to that 6000 revs, which can't be of course anyway....
However chief, the peak torque of the Subie 2.5 XT slightly drops from 236 to 229.12 lbf-ft from 2800 to 5200 rpm ;)
....2800 rpm however is already mid going top-end rpm for diesel engines, where much earlier below 2000 revs (some even starting at 1200 rpm) they were already producing sizeable broad-spread of pulling-force that is tappable even at a much greater amount of output than equivalent displacement gasoline engines, or even say just a 4-cylinder 2.2 to 3.0-litre common-rail Di turbocharged against a 3.8-litre V6 gas-fed, the latter as the case of the CX-9's 367 Nm peak torque.
When it comes to engine where torque is provided in a radial manner, this is the basic equation, which of course you also know of anyway chief:
hp = (lbforce-foot x rpm)/5252
We can check certainly the CX-9's peak 367 Nm if it can be maintained up to 6000 revs by just using that basic equation and derived assumptions from there on.... Kindly just check on my units as i might have goofed out earlier plus didn't check them anymore, just for the heck of it haha!
Cheers chief!
December 31st, 2012 03:21 AM #80
Chief, we're not arguing naman po in reality, we're just discussing on things like this, which i personally only think it's also for the betterment of those who really want to know more about the TBz 2.8 Duramax over the others....
As to the discussion on speed and power, we may go back to our high school Physics. And for simplicity's sake, say in general vector form nalang:
Power = force x velocity
Force = mass x acceleration
Therefore:
Power = mass x acceleration x velocity
Granting:
Power = watts
Mass = kilogram
Acceleration = metre/sec2
Velocity = metre/sec
In the case of the TBz 2.8 Duramax:
watts = kgweight x m2/sec3
To get how many seconds the TBz will cover say a 1/4 mile (400 metres) at different rev-range, say 2000 rpm, 2800 rpm, 3800 rpm
sec = [(kgweight x m2)/watts]1/3
Power in watts at an assigned rev-range as exampled above can be derived from brake-hp, where bhp = (lbforce-ft x rpm)/5252
And rpm, kilometre per hour, and the gear you're at can be had from calculating the engine-rev with the gearing ratios and tire specs, which gives an estimate on the following as a summary on the TBz 2.8:
For simplicity's sake, assuming a linear relationship of torque vs. rpm, estimates are:
Doing the same procedure on say the Forester 2.5XT and CX-9 3.8 V6, we can surely make a comparison at 2000 rpm, 2800 rpm, 3800 rpm, 4250 rpm granting that the auto-trannies are to shift up at these rev points. With the manual-tranny no doubt we can short-shift and rev up to the redline at any one-time we want to. There is no doubt of course chief if these gasoline-fed CX-9's and Forester 2.5XT are to rev-out anywhere between 5000 rpm and up, and the TBz only able to rev-out between 3800 to 4250 rpm, arguably, they would eat the TBz at any point in the gears....
You may provide me the gross vehicle weight, peak power, peak torque, gear ratios and tyre specs of the CX-9 to have the same type of estimate and we can then compare, chief.
The gross vehicle weight by the way of the TBz 2.8 Duramax 4x4 is 2750 kilograms.
There might be some wrong values specifically on the conversion from English to metric system, or even perhaps, the whole analogy itself ---- just bear with me chief.
Cheers!
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
