Results 31 to 40 of 135
August 21st, 2013 06:49 PM #31
Ang bare pala ng hilux E. walang body cladding.
Pero cathy, strada nalang hahaha!
Sent from my iPhone using Tapatalk 2
August 21st, 2013 06:53 PM #33
Parang may 2013 Hilux e. Mas maganda exterior Specs. Yung sa pic sobra bare pa
eto ata yung 2013 e?
4 x 2 M/T Dsl
Chassis
Suspension Front/Rear Double Wishbone with Coil Springs / Rigid Axle, Leaf Spring
Brakes Front/Rear Ventilated Disc / Leading-Trailing Drum
Steering System Rack and Pinion with Power Assist
Tires / Wheels 205 R16C 6J Steel
Drivetrain 4 x 2
4 x 2 M/T Dsl
Dimensions & Vehicle Weight
Overall L x W x H 5, 255 x 1, 760 x 1, 820
Wheelbase 3,085
Tread Front/Rear 1,540 / 1,540
Curb Weight 1,740
Seating Capacity 5
4 x 2 M/T Dsl
Engine
Model 2KD-FTV (Hi)
Type 2.5 Liter Diesel, 4-Cylinder, 16-Valve, DOHC Turbo
Displacement 2,494
Maximum Output 102 / 3,600
Maximum Torque 260 / 1,600 ~ 2,400
Transmission 5-speed M/T
Fuel System Direct Injection Common Rail (D-4D)
4 x 2 M/T Dsl
EXTERIOR
Headlamps Multi-Reflector Halogen
Front Foglamps With
Front Grille Color with Chrome
Overfenders Without
Side Turning Lamp Markers With
Outside Rear View Mirror Chrome with Side Turn Signal Lamp
Door Outside Handle Chrome
Side Step With
4 x 2 M/T Dsl
FUNCTIONS
Power Features Window (Auto Up/Down) and Doorlock and Outside Rear View Mirror
Accessory Power Outlet Front (12v)
Airconditioning System Single, Manual
Key Remind / Turn Light-Off Warning Without
Multi Information Display Clock Only
Audio System 2-DIN CD / Tuner / MP3, USB & Auxillary Input, 2 speaker
4 x 2 M/T Dsl
INTERIOR
Seats Front Sliding, Reclining with Headrests (2 pcs.) and Driver Vertical Height Adjust
Seats Rear Bench Type, Tip-up Function with Storage
Seat Material Semi-Fabric
Meter Guages Analog
Instrument Panel and Center Cluster Standard
Shift Knob / Shift Boot Urethane
Console Box With Lid and Rear Cupholder
Cupholders / Bottle Holders Front Instrument Panel (2 pcs.) + Door Trim (2 pcs.)
Cupholders / Bottle Holders Rear Console Box (2 pcs.) + Door Trim (2 pcs.)
Sunvisor Driver (with Ticket Holder) + Passenger (with Vanity Mirror)
Door Trim Moulded, Fabric
Door Pockets Front and Rear
Inner Rear View Mirror Day and Night
4 x 2 M/T Dsl
Safety
SRS Airbag Driver
Seatbelts Front/Rear 3 pt. ELR x 2 / 3 pt. ELR x 2 + 2 pt. NR x 1
Child Proof Lock With
High Mount Stop Lamp Without
Sidedoor Impact Beams With
ABS With
Vehicle Security System Without - BAD TRIPLast edited by _Cathy_; August 21st, 2013 at 07:00 PM.
August 21st, 2013 06:57 PM #34
Better to visit a dealer, Cath.
Yan kasi itsura ng Hilux E na naalala ko. Recently kasi puro G na nakikita ko.
August 21st, 2013 07:03 PM #36
August 21st, 2013 07:25 PM #37
*Ts
Im not so sure, but I think the manual Tucson and Sportage go for just under 1m
These SUVs ride far better than a hilux or strada, with a decent wading depth (388mm according to some Indian car forum)
Dont know if Im high or not, but there is a 993k Isuzu Dmax that has an automatic tranny
August 21st, 2013 07:33 PM #38
August 21st, 2013 07:44 PM #39
Ayaw mo L300? haha.
Magstrada GL ka na lang then palit mags. Ayos na ayos na yun. Pasok na pasok pa sa budget.
#Retzing
August 21st, 2013 07:47 PM #40
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
