ayaw po gumana ng links (sorry mods, hindi ko po alam na bawal)
Ads ID na lang po:
Tribute - 4775285
Escape - 4887093
Regarding Escape, 2L lang po pala. Ano po take nyo dito?
Many thanks po ulit![]()
Ads ID na lang po:
Tribute - 4775285
Escape - 4887093
I'd just talked with the seller of Red Escape, may problema lang daw sa fuel pump..nagha-hard starting daw. Pero ok daw manakbo pagka-start. around 3k daw abutin ng pagawa.
frake - 2 liter Escape is a bit sluggish if 3-4 people inside that car. Pero kung 2 lang kayo ng misis mo kaya pa. About the fuel pump, how sure the seller yun lang ang problema? Baket hinde nya na lang muna paayos bago nya ibenta? Kahit wala kang kilala na mechanic, magdala ka pa rin. Bigyan mo lang 1k for checkup. Yung sa pinsan ko nung bumili sya ng 2nd hand 2006 Altis, nag join sya sa Altisclub and hired a member para samahan sya to check the car :-)
maraming salamat sir sa input. Gawin ko po advice nyo. Naghahanap din po ako ng 2.3L. And yes, nasa 3-4 people nga po ang magiging sakay lalo pag weekend. Do you recommend a higher displacement that 2.3L?
About the seller, naapreciate ko din naman yung honesty nya and the tips to look after the fuelpumps specially for 2nd hand Escape at common daw po na sakit yun ng Escape. Hard Starting din daw po pag mainit ang makina due to fuelpump problem. He also mentioned yung power steering hose eh palitin na din.
frake - Kung kaya ng budget sir ha dun ka na sa 2.3L mapa Escape or Tribute. Saktong sakto talaga sya at wala na yung mga issues sa previous generation. Once nakabili ka na, pa check up mo sa casa agad, kung may extra money dun mo na rin pa maintenance. Pag short, sa labas na lang dame naman OEM parts sa banawe.
Kung ganon, wag mo na kunin ang Escape na yan lalo na may topak pa. And for 350k may makukuha ka nang V6 eh. The 2.0L Zetec drinks gas like a small displacement V6 and performs like 1.8L.The Tribute looks fresh, if you have the budget you may consider checking it out.
Sir GTi, V6 po ba is 3L? what do you think is best when it comes to durability, 2.3L or 3L? kasi kung makakamura nga ako sa gas pero tagaktak naman pawis ko kasi ititirik ako sa daan, siguro i-consider ko na lang yung durable.
regarding posted ads ng mazda, eh nakuha na daw po. yung isang white hindi pa po sumasagot. meron ako kinakausap na escape an 2.3L. If ever silipin ko po today.
Hi Sirs, had just visited the white tribute. It looks okay and has no problem with the starting. May konting gasgas which is understandable. Napansin ko lang pag nasa idle or moving pero hindi nakatapak sa gas eh meron vibration. Ano po take nyo dito mga sirs?
May mga schedules pa po ako sa ibang seller hanggang till the end of the week (nakakapagod. considering taga Bacoor ako and Ortigas yung pinuntahan ko)
Yes 3.0 ang V6. Sa durability naman, the two come from the same Ford Duratec engine family and were released at pretty much the same time so engine design and construction should not be too far apart.
Anong klaseng vibration? May tunog ba? Gaano kalala ang vibration? Kung hindi naman matindi siguro naman normal lang yan. Try checking out other Tributes and see if they exhibit the same sort of vibration at tanungin mo narin sa kanila about that. But then, our Escape 2.0 vibrates while idle too (though that should not be used as a benchmark since they use different engines, and from different engine families), maybe it has something to do with the cabin or engine mounts not being able to thoroughly filter the vibrations?![]()
so either V6 or 2.3L would be a great choice when it comes to engine quality. ganun po ba sir?
sa vibration, may konting sound..siguro po kasi yung dashboard and other panels eh naaalog din po. hindi pa naman po katulad ng sa jeepney and vibration. Kaso lang dun ako ilang na ilang pag nag-gaganun yung gamit kong auto (Vios 1.5G).
Yesr, sir, gusto ko din talaga mabisita yung ibang seller for comparisson din po.
Many thanks po ulit, sir GTi.
Both are great engines naman. And unlike some other engines, there are no known issues with them. So purely SOUND lang yung sinasabi mong vibration? There is nothing you feel? That car is very solid naman, I couldn't think of anything that is supposed to go loose. So far the only time I heard a rattling sound associated with vibration in our Escape, it was the stereo head unit that was somewhat loose from its mountings. It was quickly remedied by inserting a 10 peso coin on the gap. Is the vibration not associated with the engine running somewhat unrefined? Yung parang diesel na naka idle? If so siguro medyo mababa lang ang idling niyan, which can be easily fixed.
Meron naman atang switch yan sa Outlander. If the one you saw was selling for 300+k then it must be the 1st gen version, which is not a good buy. The drivetrain is excellent, being derived from the Lancer Evo but the engine is a major letdown spewing only a paltry 136ps out of 2.4L of displacement which means performance isn't good and so is fuel consumption. The Outlander worth buying would be the 2nd gen which is a very, very good car that is still capable of battling it out with the current CUV offerings in the market but then that is out of your budget already...
i will, sir. actually earlier meron kami ni misis pinuntahan na escape. biglaan lang kami napapunta kasi yung kaibigan ko ang may kakilala sa seller. the vehicle is a 2L 4x2 Escape. Makinis and orignal pa yung paint. he interior naman is medyo amoy luma as the car daw was not that maintained by the owner since nasa abroad. Pero kung titignan mukhang ok pa talaga. all the functions are working well. This time ako nag drive, naramdaman ko yung bagal, kaso my comparison naman is the vios i am using at the moment. medyo parang mabigat...and parang under power nga. May vibration din na parang nung sa Tribute. Medyo gusto ko na namin ng misis ko kunin since the price is only 300K.
Tomorrow meron pa'ko titignan din na escape. I-try ko din na i-drive then i will let my instinct make the decision. Pero syempre kung magugustuhan din ni misis..hehe! :D
