Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 68
    Aug 2004
    #41
    Quote Originally Posted by GTi View Post
    OK to ah, drag-van! Kumusta naman ang handling ng Alphard?
    Surprisingly, quite good.
    The Alphard is based heavily on the Camry.
    Unsurprisingly, during our testing, the Alphard drove just like that... a much heavier Camry V6 with a slightly longer wheelbase.
    It was less than a second slower to 100 km/h (faster, in fact, than a V6 Explorer). It was almost as quick through the slaloms. And it braked slightly better... probably because of the better front-rear weight distribution.
    I would, without hesitation, take an Alphard out on the racetrack. Good steering, low center of gravity (despite the tall looks, a van like that has all its mechanicals down low, unlike an SUV where the floor, differentials and engine are raised higher off the ground), great brakes.
    All you would have to do to make it more potent is to strip the interior and power amenities. It's around 2 tons, that would take it down to around 1.8 tons. Then replace the doors with carbon fiber or even just fiberglass. Add a sports suspension (hoping Camry struts and springs fit) and you're done!
    Of course, it would be nice to add a supercharger for more oomph...
    May 2010
    #42
    booyah! Alphard V6 drag racing van! it would be faster than an E150 right?
    *TS: dapat nag SiR ka nalang. kiddin' :rofl:
    Pa-pogiin mo nalang ung RS. buy orig 19" Advan wheels then better looking and grippier tires and a CF chin.
    #43
    Quote Originally Posted by SiRbossR View Post
    Naghahanap na ata siya ngayon ng Alphard with carbon fiber doors.
    Amusing how i remember the TS started by just looking for a car since ayaw lang niya ata mag commute/taxi after his model shoots or something... ngayon gusto na niya rezing-rezing. Follow what the others said and don't listen to the BS some people tell you of having to mod up, "gauge", etc... There will always be bigger fish in the ocean and if you want to have serious speed, you better have the bakal, skills and wallet to back it up. And do keep it off the streets.
    Go with what SiRbossR said. Keep it clean, put nice mags and just keep the car maintained and running well.
    #44
    ... AND if you do have to go street racing, make sure your car have enough engine power & performance to blow the doors off car twice your size. Unfortunately, basic bolt-on mods will not achieve this level of performance.
    #45
    Gash imagine when the current gen Impreza starts to trickle down to the second hand market at low prices.
  6. #46
    since nasa usapang mods, may plan ako magpalagay ng mga ito sa carens ko.. ask ko lang anu effect nito sa handling? as i recall nasa 20-25t ang kumpletong set na ito...hanapin ko lang pdf file ko..
    Kia Rondo 2009 Strut Bar Manufacturers, Suppliers, Exporters, Importers, Wholesalers, Products- Sway bar,rear anti roll bar,strut tower bar,front lower braces,chassis stiffness,
    #47
    Quote Originally Posted by alwayz_yummy View Post
    Less chassis/suspension flexing makes handling better & sharper.
    Note: suspension upgrades for better performance usually ends up with (bad) stiff ride which is uncomfortable as daily driver. The key in a daily driven street car is the balance between comfort & performance.
    Aug 2004
    #48
    On the Carens, I'd go with the rear anti-sway bar and the front four-point. Forget the tower brace, most modern cars don't need it since the strut towers are triangulated into the firewall already.
    I don't know if you'll notice the front four-point or tower brace, but you'll definitely notice the rear anti-sway bar on a vehicle as soft as the Carens.
    May 2010
    #49
    Yup, Dapat stick with the plan nalang muna which was buying the lynx for your daily commute and as to that, we all know what you have now will suffice your needs.
    Just keep it clean and maintained properly bro. Enjoy mo muna yung stock power.
    bad influence talaga mga kaibigan hehe
    ok na sana ang stock na sasakyan pero sasabihin sayo palitan mo ito, palitan mo yan, bili ka ng ganun, bili ka ng ganyan...
    before you know it you've withdrawn 50K from your ATM
    Apr 2008
    #51
    Hehe... Peer pressure is a powerful thing, bro. Since he has already started installing bolt-ons and his D15B friend has challenged him to race... :devil: We shall then help him smoke that thing! :hysterical:
    #52
    50K does not even pay for the adjustable suspension upgrades.
    hehe 50K is just for beginners
    then as you mature (graduate ka na from Simota and Rota... you become more demanding and your taste improves... Japan aftermarket parts na... like Apexi, Defi, HKS, Rays, Tein, Tomei, Cusco, Endless, JUN etc) so you're talking 500K up to millions na
    when you're bitten by the bug...
    #54
    Years ago I bought a 2nd hand B14 Sentra with a SR20 engine for a little over P200K. It was fast but I wanted to go even faster. I spent well over P150K in parts alone (labor not yet included) to make it go faster and handle better. Wheels, tires, custom exhaust system, piggyback fuel management ecu, adjustable rate shocks, track-rated lowering springs, K&N filter, electronic speed de-limiter, etc. And a few hours of dyno tuning to get the engine to perform its best.
    ya ganyan talaga. you're never satisfied
    kaya kahit naka Evo ka na gagastos ka parin sa mods
  16. #56
    lambot nga ng suspension ng carens, not much fuzz sa city drive, pero pag sumulong highway or ung pababa sa teresa or pag country roads, lumalabas ang pagiging ma-buway nya...
    so una ko invest is the 4-point low brace Front Lower Bar / Front Member Brace (UR-LA4-766) and 19mm rear sway bar? how about the front low 2-point Front Lower Bar / Front Member Brace(UR-LA2-765), Rear Lower Bar / Rear Member Brace (UR-RLS4-767P)-pair, Rear Lower Bar / Rear Member Brace (UR-RL2-768) and for me kasi having a front tower bar pampapogi nalang halos sa engine bay e..
    anu po sa tingin nyo kunin ko sa set na yun na magbibigay ng balance between comfort and performance-->kahit pan-track-days lang.RWYB is not my priority, pero kung makakapasok, why not..
    ask ko lang din--may effect ba ang paglagay ng o-suley?
    nagmomod ako para mameet ko ung hinahanap ko drive na gusto ko... ie. ung x-xtrail ko.. di ako nagfocus sa mods kasi performance wise its good enough for me... matakaw nga lang sa gas!
    sleeper mode mods ko....pag nakasakay si amo dapat tame..pero pag gusto ko maglaro, dapat game..di ako makakaramdam ng hesitation from my ride.
    Nov 2011
    #57
    Dapat pala talaga nagcommute nalang ako.. Wahahahaha, Pero tingin nyo, anong bagay na mags sa itim na RS? Mas trip ko kasi 16's lang eh para di naman hurt performance. Bagay kaya sakin yung CF hood, CF bumper. CF grill? )
    #58
    basta kung ano sinisigaw ng puso mo at may pera, banat TS!
    Apr 2008
    #59
    Quote Originally Posted by michaelbelen View Post
    Agree with what sir chua has said.
    But if you ask for my opinion, personally I find the stock RS rims to look good. At 16 inches it already fills up a large part of the wheel well and I find it big enough. If you further go up to 17 inches, ride quality will suffer a lot. Trust me, there is a very noticeable difference in terms of ride comfort between our Accord 2.4 which uses stock 16 inch rims, and our Accord 3.0 which uses aftermarket 17 inch rims. And then you will have to retune the suspension, change the shocks, hassle, hassle, hassle. So if the 16s look good and you're tired of your old rims, then go for 16s still.
    Huwag na kasi lagyan ng CF. Mahal yan at hindi classy ang dating so kapag nagtagal yan mag-iinip ka rin diyan at maniwala ka sakin, ibabalik mo rin yan to its original look.
    Aug 2004
    #60
    CF hood looks good on a black RS... other CF parts... not needed.
    Stock wheels are super pogi... if you ever change them, don't trade them in. They're in high demand and are VERY hard to find outside.
    If you want to make them look more aggressive, buy a 205/50R16 or 205/45R16 tire with rim guards. They'll give you a very nice, square chunky look on the stock wheels.
    Rear sway... definitely a good addition. Up to you which one you want most in front... a front lower sway bar might have more effect than the four-point, but it will depend on the car. I know a little about the Carens shortcomings, but I only drove it for a short while.
    Everything else, up to you... The Carens CRDi is super quick for a seven seater... so suspension and tires are really the only things you need to address. Perhaps better brake pads for more bite, but you're limited in applications. Perhaps the RunStop guys can help you find out if other Hyundai-Kia applications will fit (like Elantra brakes, for example).
    But of course, anytime you use your full braking capacities on the road, you're driving way too fast. Suspension should do it for you. With a good set of bars, the handling will improve more than simply stiffening the springs.
Help: car mods/upgrades
