unichip and emanage are both tuning chip right? Hindi ba ganun kadelikado magpa PnP?
pareho piggyback ang e-manage and unichip
but you can control a lot more with e-manage
Hey, you can do a hell of a lot more with Unichip. (multi-maps, extra-injector maps, electronic throttle-mapping, MAF-MAP conversion, launch control, auto-map switching when on nitrous, O2 sensor compensation, alcohol-injection control, etcetera...) The problem is you're usually locked to the tuner, because tuning kits are not commercially available, and every additional feature is additional labor charges.
Forget the CF bumpers and trunk. The lightening is not anywhere near enough to make it worth it.
Forget PnP. I've done it. The bump in power is completely negligible. COMPLETELY. I've done it. I had the best PnP money can buy. But with stock cams or even FSZE cams, you're not going to see any benefit. You really need US-made racing cams.
Versus a lightweight D15B, with just exhaust and an E-manage, you'll be on somewhat even footing, but he'll definitely beat you off the line. The Lynx is heavy, no doubt about it. But that weight is not something you can fix with carbon fiber body panels. All that extra weight is in the sunroof (around 30 kgs) and the engine (maybe 50 kgs extra due to the iron block).
Just do the simple stuff. Forget about gauging. The RS is not great for drag racing. Heavy engine, clutch not that durable. First gear too short. Second gear too long. And even if you fix the clutch, your engine mounts are too soft and third gear is too fragile (just as in the Sentra... which is at least lighter).
Even with my fully modified RS, which has racing cams and the highest naturally aspirated horsepower in the Philippines (around 152 whp... approximately 175-180 bhp), because of the weight of the car, it still does high-15 to 16 flat quarter-miles. Modified 1.6 Sentras and D15Bs can kick my ass on the drag strip... even though I can hit near-230 km/h and leave them for dead on the highway.
Just do what you want to do to feel good about the car. But don't feel bad if you lose a drag race or two, as the Lynx ain't a good drag racer.
sir abs, reasons at previous replies po..
Sir better po ba standalone? That's 60k po kasi. Pero will it be satisfying? Will my 60k do much and improve my car better compared to piggybacks?
o diba? standalone
dude, unless your engine is heavily modded you dont need standalone engine management
heavily modded as in turbo, bigger injectors, etc
what your mind wants doesnt match your budget
your 65K will only buy you a few horsepower no matter what you spend it on
if you want big noticeable power increase you're talking 200K up
E-Manage is great if you know what you're doing, otherwise, if you're a newbie (like the TS is), better to leave it to an expert.
Problem is, the Power FC has limited compatibility. The Unichip is at least nearly universally applicable.
And for all that money, as you say, you're only going to get the same hp. The only big advantage of the Power FC is that you can avoid fightback (which we already do with Unichip and E-Manage by removing the O2 sensor or emulating it with the Unichip) and you can raise the redline.
That's the one thing the Unichip can't do on the Lynx. We tried the Unichip redline defeater module and it doesn't work for the RS. But even raising the redline will get you very little, as the stock cams and FSZE cams don't breathe past 6500 rpm. You need 40k pesos worth of racing cams to make it worth your while. And while you're at that, you'll need cam gears, an oil pump upgrade, new valve springs and a balanced and blueprinted bottom end, because the FS-DE hates high revs. Throw in individual throttle bodies and a MAP-MAF conversion, which can be done with the Unichip, and which gains you about 10 hp alone. But you have to have contacts in Taiwan to get the set-up from AAI.
Tama nga estimate mo. Mga 200k. High comp pistons, balancing, racing cams, stronger connecting rods, standalone ECU, etcetera, etcetera, etcetera.
Whereas with just 100k, puwede nang turbo.But you'll still need a better oil pump, otherwise the engine goes "pop" at over 200 whp.
Pa-guwapuhin mo na lang car mo. Better brakes, sound set-up and lights. Wag na habol sa speed kasi kapag nakasabayan mo mga korean SUV's iiyak ka din. hehe
Fasten your seatbelt! Or else...Driven To Thrill!
Hahaha... it'll be close. I can beat the Alphard to 100 km/h, but just barely. Above that, I'm sure the Alphard would kick my ass.
I wonder if I can turn it into a drag car by dumping out the interior? Can you imagine the looks on the drag-boys' faces? A huge van doing consistent flat 15's all day, and taking home the bacon in the bracket races.![]()
Nakakagulat nga yang Alphard. I was beside one at the lights. Pag-green nawala na lang bigla.
