Results 1 to 20 of 64
    danieyoyo!
    SQ set-up kailangan yong sinabi na Imaging na sa front..(yong kumakanta must somhere in front/mid of the listener and as wide as possible and bare in mind you need to hear the instruments properly as well) to do this it is a bit tricky..kailangan mo lang hanapin kung saan maganda e lagay ang mga speakers mo..Some people they put the speakers sa kick-panel aiming high or towards the listener..and the tweeters na sa pillars eye-level to the listener.. setting up needs planning, time and sometimes "trial and error"...kung sa pinto naman kailangan mo rin e-adjust at aim yong mga speakers hanggang ma-achieved mo yong gusto..na parang "concert setting" . Good luck!
    Apr 2008
    Quote Originally Posted by xtian_joyaxx View Post
    danieyoyo!
    thanks sir,
    pero with my current set-up ba do i need to add something pa to get that or kailangan ko nalang mag adjust?
    Quote Originally Posted by danieyoyo View Post
    thanks sir,
    ok na yan. all you have to do is proper aiming. mag upgrade ka na lang if hindi ka na satisfied sa tunog. hehe. or should I say wag ka muna makinig sa setup ng iba para ma enjoy mo yang sayo. mahirap pag nakapag audi ka ng ibang setup sigurado matetempt ka mag upgrade. hehehe
    Apr 2008
    Quote Originally Posted by flakez View Post
    hehehe..tama ka sir, satisfied naman ako sa sound ng sakin, yun nga lang may nadinig ako na isang car na parang concert ang sound... may naobserve lang ako na isang problem and baka ibalik ko sa nagkabit, napansin ko na parang may "whistle" na sound pag naka on ang audio ko then pag umapak ako sa accelerator eh lalo lumalakas, ano kaya yun?
    Achieving a good imaging, sound stage and and dynamics is not easy, it takes patience and *** (trial and error) install and tuning as Posted by xtian_joyaxx.
    yung naririnig mo it static usually caused by improper grounding, or wiring.
    yup static yan. add ka lang ng ground or upgrade ka na ng big 3 para ok. akin din ganyan dati, nag add lang ako ng ground wires ok na.
    Apr 2008
    salamat ulit...
    sabi ko na sa ground yun kase may nabasa nga ako dito na dapat sa solid metal makabit ang ground hindi basta sa metal part lang eh pwede na...
    eh sa may hinge/support ng compartment lang nakakabit eh
    Jan 2008
    naka ipod kaba thru AUX INPUT?? or any device connected to AUX INPUT?? if using aux input do not charge your device while playing.. the charger creates a "loop" that will cause that whistling noise
    what is your HEAD UNIT?? PIONEER?? sometimes if you get your signal for the subwoofer from the subwoofer output of the head unit it may result to whistling sound or static..
    Apr 2008
    *yapoy
    yes gumagamit ako ng AUX, pero d ako nagchacharge sa car.
    actually napansin ko yung sound nung nasa nlex ako na parang sumasabay sa apak ng accelerator. so nag observe ako kase baka sa belt lang. pero wala ako nakita sa engine so nung nagstart ulit ako and nag power ng stereo dun ko na narinig ulit yung whistle sound.
    about head unit yeas pioneer 2050 po, may amp naman po ako na gamit sir. dinig ko yung static sound sa separates
    Apr 2008
    ok na static i bought this anti-static, nawala na yung huni... ano ba usual cause nyan?!
    isa pa tanong...
    papano ba mag balance ng sound using yung cross-over na nasa amplifier? i mean paano ang adjustment... lets say sa sub.. yung sub ba dapat as in Bass lang lumalabas at wala kahit voice? then sa midbass ng seps parang masyado kse malakas ang bass na pag nilalakasan ko na eh malakas din yung vibration na pinto.. sensya na matanong masyado... inaaral ko pa po kase ang about car audio settings...
Please Help on audio upgrade
