I didn't actually weigh it but it's probably equal to sub-Php10,000 6.5" midbass thanks to its
huge ferrite magnet.
Truthfully, it's cheap at 6,000php per piece pero ang laki ng dagdag nila sa shipping.. haha. It seems the CM series uses ferrite as a cost-saving measure over the more expensive neodymium magnets found on the 6" FST of the Series 800. The 6" FST costs roughly 3 times as more thanks to skyrocketing rare earth prices.
I haven't actually tested it, but it shouldn't be far from how the 6" FST measured. The magic of the suspension is that it has very limited linear throw but it makes it up for this for its efficiency. While most car midranges has a sensitivity of 85dBs, these are 95dB-efficient. A figure attained because of very good magnet flux (magnet pull which increases sensitivity) and because of its surface area (a 5" has 2.7x more area than a 3" cone).
The problem when I competed kasi was that
Thai judges were telling me I was hitting power compression at high-volumes on my midrange. This was causing it to lose detail and distortion is rising. The reason for this is that my aluminum billet enclosures doesn't have a lot of air volume and that lowers efficiency as you need more wattage to hit a certain dB. More wattage = more heat = less magnetism = power compression.
Anyway, to remedy it.. naghahanap ako ng efficient drivers. Problem is, there's no product in car audio that will satisfy my requirement of efficiency and low distortion until I came across B&W's midranges. To put their efficiency as an idea for you..
Give both speakers 2 watts and the FST = 95dB and the Focal 3W2 (Focal Utopia midranges.. roughly 30,000php per piece) = 85dB. Let's say I need to reach 100dB, this means I need a +5dB gain on the FST and +15dB on the 3W2. As power is exponential with regards to decibels,
I'll need 63W on the Focal to reach 100dB while I only need 6W for the B&W. 50W of excess power is very hot.. ever touched an incandescent light bulb? Second degree burn na agad yan. And this is taken on their most efficient setting -- free air. Throwing them into an enclosure will further increase their power handling and decrease efficiency.
That's how you scream and shout. Audio is science naman.. not really hard
not unlike somebody here na hindi alam bakit malambot at matigas tumunog isang speaker.. really productive twelve years he has.
