hi guys,
i just want to ask kung pano mg set up ng audio system s ride? kung ilan ang subs, ilan ang ampli at kung kailan my crossover at how much ang budget n kailan to produce a loud and kicking car audio set up.
Its better if you post this thread sa "car electronics". This thread will be moved there by the mods.
Medyo mahirap sagutin ang tanong mo kasi napaka broad.
Pano magetup ng sounds? Dalhin mo oto mo sa installer at pakabit mo sa kanila. Sabihin mo kung ano type mong music at budget mo. Ano ba gusto mo sq, spl or sql?
1. Start ka sa HU (head unit) suggest Pioneer 4950 kumpleto na ito at ok tumunog. Budget mga 5000 pesos.
2. Bili ka ng seperates para sa harap. May kasama na yan na crossover. Get the biggest that will fit in your stock speaker location. Try to listen to them before buying. Lots of choices available. From cheap Targas (ok na sound nito) to very expensive highend Focals and Peerless. Abot 22K.
3. Get a 4 channel amp. Match it with your seps and subs power handling. Again lots of choices from cheap Taiwan amps to competition amps that will blow your wallet. Most amps are equipped with crossovers.
4. Buy your sub and enclosure. Box is usually around 2-3K. Subs, price will again depend on size, brand and quality of the sub.
5. Dont forget your wiring. Around 1-2K. Better thicker wires will give better sound.
You dont have to buy it all at the same time kung bitin ang budget.
*Daelo:
1 HU na 4 up volts out
1 12' sub with calculated ported box
1 set of seperates
1 mono amp
1 4 channels amp
power wires g 4 if above 1k watts(depende sa wattage ng amps)
1 capacitor
1 sets battery clamps
1 fuse block with volt meter
90 amps alternator or higher
and isang magaling na installer
ako din question na din since ala ako masyado alam sa set-up.
1. sa seperates, may nakikita ako na speakers na hiwalay ang tweeters and 3-way speakers w/ built in tweeters, alin ang mas maganda?
2. gusto ko sana nakatago yung subs, my ride has 2 extra speaker slots na i think 5 or 6" ang fit. nakakita naman ako subs that size na 300w lang. ok na ba yung 2pcs 5"/6" subs or mas maganda talaga yung mga 10"?
3. sa amps, how many wats should i get?
4. any shops recommended sa south para sa audio set-up?
Need help ask ko lang sna ano po ba yung specification ng hyundai accent 2011 speakers, ska ilang oms.. May bnebenta kasi skin na amplifier.. E dko alam yung speaker ng car ko.. Bka kasi masunog pg kinabit ko yung ampli thanks
