Quote Originally Posted by recklus View Post
1. ok, ang dami ko na kasi nakikita sony and pioneer na tri-axial, are they good or may alam po kayo na mas maganda?
2. so if i'm going for the 10" or 12" ano po ba mas maganda? maliit yung box or malaki? when i asked 2 difft shops kasi magkaiba ang reply sakin, yung isa mas effective daw pag maliit lang yung box, the other kabaliktaran, the bigger the better daw
3. ah ok, tama po ba tong naiisip kong idea? example seperates 130w each = 260 + 1200w sub = 1460w. so yung total W ang hahabulin kong amp na ikakabit ko sa kanya? are v12 amps good?
ty po sa reply sir, you're a big help.
Sir what should be the preferences? for sound quality or for boom boom!
1. go for the separates, will make it easy to aim the components
2 10 or 12 on a sealed or ported box will do, just be sure to get the exact box calculation for the subs! 10's sounds good in a calculated .75cft sealed box! unless you are willing to sacrifice your cabin for the box!!! go for the 12's
3.what brand of drivers? does the watts indicated are in 4 ohms? driver performs good when it will be feed on its rated watts,and great on feed a little bit high! try to get a branded one if budget does not constrains V12 amp are over rated!!!
hope this helps good luck!!!
