Results 1 to 10 of 14
- Oct 2007
- 1
October 12th, 2007 09:16 AM #1hi guys,
i just want to ask kung pano mg set up ng audio system s ride? kung ilan ang subs, ilan ang ampli at kung kailan my crossover at how much ang budget n kailan to produce a loud and kicking car audio set up.
Tsikot Member Rank 4
- Jun 2006
- 2,605
October 12th, 2007 10:32 AM #2Its better if you post this thread sa "car electronics". This thread will be moved there by the mods.
Medyo mahirap sagutin ang tanong mo kasi napaka broad.
Pano magetup ng sounds? Dalhin mo oto mo sa installer at pakabit mo sa kanila. Sabihin mo kung ano type mong music at budget mo. Ano ba gusto mo sq, spl or sql?
1. Start ka sa HU (head unit) suggest Pioneer 4950 kumpleto na ito at ok tumunog. Budget mga 5000 pesos.
2. Bili ka ng seperates para sa harap. May kasama na yan na crossover. Get the biggest that will fit in your stock speaker location. Try to listen to them before buying. Lots of choices available. From cheap Targas (ok na sound nito) to very expensive highend Focals and Peerless. Abot 22K.
3. Get a 4 channel amp. Match it with your seps and subs power handling. Again lots of choices from cheap Taiwan amps to competition amps that will blow your wallet. Most amps are equipped with crossovers.
4. Buy your sub and enclosure. Box is usually around 2-3K. Subs, price will again depend on size, brand and quality of the sub.
5. Dont forget your wiring. Around 1-2K. Better thicker wires will give better sound.
You dont have to buy it all at the same time kung bitin ang budget.
October 15th, 2007 01:48 AM #4
guys, ano recommended shop in las pinas/paranaque/alabang area for audio set up?
October 20th, 2007 02:48 AM #5
*Daelo:
1 HU na 4 up volts out
1 12' sub with calculated ported box
1 set of seperates
1 mono amp
1 4 channels amp
power wires g 4 if above 1k watts(depende sa wattage ng amps)
1 capacitor
1 sets battery clamps
1 fuse block with volt meter
90 amps alternator or higher
and isang magaling na installer
October 24th, 2007 06:26 PM #6
ako din question na din since ala ako masyado alam sa set-up.
1. sa seperates, may nakikita ako na speakers na hiwalay ang tweeters and 3-way speakers w/ built in tweeters, alin ang mas maganda?
2. gusto ko sana nakatago yung subs, my ride has 2 extra speaker slots na i think 5 or 6" ang fit. nakakita naman ako subs that size na 300w lang. ok na ba yung 2pcs 5"/6" subs or mas maganda talaga yung mga 10"?
3. sa amps, how many wats should i get?
4. any shops recommended sa south para sa audio set-up?
- Jun 2006
- 2,605
October 24th, 2007 07:03 PM #71. Yung nakahiwalay ang midrange sa tweeters ang seperates, yung built in ay tri-axial. Generally, masmaganda ang seperates pero depende ito sa brand and model at install.
2. Baka mabitin ka sa 5 or 6".
3. Match mo sa power requirements ng speakers. Ok lang kung sobra o kulang ng konti.
October 24th, 2007 11:59 PM #81. Yung nakahiwalay ang midrange sa tweeters ang seperates, yung built in ay tri-axial. Generally, masmaganda ang seperates pero depende ito sa brand and model at install.
2. so if i'm going for the 10" or 12" ano po ba mas maganda? maliit yung box or malaki? when i asked 2 difft shops kasi magkaiba ang reply sakin, yung isa mas effective daw pag maliit lang yung box, the other kabaliktaran, the bigger the better daw
3. ah ok, tama po ba tong naiisip kong idea? example seperates 130w each = 260 + 1200w sub = 1460w. so yung total W ang hahabulin kong amp na ikakabit ko sa kanya? are v12 amps good?
ty po sa reply sir, you're a big help.
October 25th, 2007 02:29 AM #9
Sir what should be the preferences? for sound quality or for boom boom!
1. go for the separates, will make it easy to aim the components
2 10 or 12 on a sealed or ported box will do, just be sure to get the exact box calculation for the subs! 10's sounds good in a calculated .75cft sealed box! unless you are willing to sacrifice your cabin for the box!!! go for the 12's
3.what brand of drivers? does the watts indicated are in 4 ohms? driver performs good when it will be feed on its rated watts,and great on feed a little bit high! try to get a branded one if budget does not constrains V12 amp are over rated!!!
hope this helps good luck!!!
October 25th, 2007 10:05 PM #10
ty bro toolightz, im going for quality. one more question hehe, with that set-up, do i need to upgrade something with my battery and alternator?
Xiaomi E-Car
