Page 224 of 307 FirstFirst ... 124174214220221222223224225226227228234274 ... LastLast
Results 2,231 to 2,240 of 3070
    Jan 2017
    #2231
    *sientobente, Sir, ung seps mo po ba sa Swift is ung Flux FS260 pa rin per your previous post? Am also thinking on what is the best amp for those seps
    Feb 2011
    #2232
    Quote Originally Posted by 8eight8 View Post
    Yes sir, still the FS260 on the Swift. It is paired right now with the Gladen M95.4. Avoid the Flux amp, ang dami nagsasabi substandard ang quality plus my friend said it sounded dry. I think, warm sounding amps like Audison, Genesis and Celestra will also match Flux Seps from it's entry level up to it's higher priced variants. Meron din ginawa yung installer ko na paired with the Helix G-Four, maganda din ang pairing.
    Jan 2016
    #2233
    Good afternoon sirs! I'm new to the Car Audio scene and would like to set-up a Honda City 2009. Budget is around 30k but can still be stretched depending if the product is really worth it.. I'm more into Sound Quality than Bass. Please guide me with what parts should I go for..
    Jan 2017
    #2234
    Quote Originally Posted by sientobente View Post
    Thanks for the advise sir. I am also considering Helix for the amp para sa Flux seps. Good to know na maganda pairing nila How about Rockford amp sa Flux FS260? Ok rin ba sila?
    Aug 2010
    #2235
    Quote Originally Posted by mouseketeer View Post
    The best route here is to listen to a properly tuned SQ car so you can set your standards and aim. Expanding your budget range due to it is optional but is what usually happens.
    Kidding aside, as a start set aside:
    Php 5,000 - Speakers
    Php 5,000-8,000 - Amplifier
    Php 3,000 - Deadening
    The Rest: Labor and Wires
    If you'll do it step by step, unahin yun deadening and speakers.
    Jan 2016
    #2236
    Quote Originally Posted by jhnkvn View Post
    Sir thank you for the guidelines! Will take this into comsideration!
    Aug 2010
    #2237
    Just remember guys that the best amplifier is an amplifier that does not color the sound and outputs gob loads of power (at least what you need).
    Amplifier matching is applicable in Head-Fi where your source is direct and speaker drivers are just centimeters from your earcup. It's also partially applicable in home audio as you can somewhat remove the environment as a variable through well-placed acoustic treatment.
    However, amplifier matching is non-applicable in a car setting as there are a ton of variables that will differ each car's sound.
    - Vehicle interior acoustics alone colors the sound much more than your amplifier and speakers' mood swings
    - There's the noise floor coming from outside
    - And the fact that you can't really nitpick the details in the music while driving 60km/h
    And if you want to argue, Dan D'Agostino's costs Php4,000,000 per monoblock (so you need roughly Php8M to power two speakers) are rated 20hz-20khz at a strict adhesion of +/- 0.1 decibels. If amplifier matching is so vital, why does one of the best amplifier brands not do it?
    Apr 2006
    #2238
    Good pm mga boss. Im planning to get my 2005 Jazz an audio upgrade. Can you suggest what can i get with a budget of 15k not including the HU. Thank you for the reply.
    Aug 2010
    #2239
    Quote Originally Posted by cucoy View Post
    Find a good installer
    Buy a good separates component
    Deaden your front doors
    Fiddle with your head unit's settings to adjust EQ
    Feb 2011
    #2240
    I respectfully disagree bro on amp matching. I know though where you are coming from. There are amp builders from DIYMA and PDVD who says the same, but in reality, they never even did an A/B comparison with multiple amps. But we did. We had a lot of those in PDVD. Even Paeng/cyberdraven did one a few years ago. The outcome? One of those local amp maker's amp (who actually says the same), paled in comparison to those "branded" amps. His amp was rated the lowest consistently among many listeners :D
    The best way to test this out on a car environment is doing an amp switch on the same vehicle. Engines off, same quiet location. Peter Lee did this on my Rav4 back then. It was a Crunch 50wpc vs Soundstream 130wpc. Spec-wise, Soundstream kicks ass. Has a better SNR, THD, Power and even has the highest Damping Factor I saw in any locally sold amp. So was it a match on the Focal 165VBs I had in the car? No. Soundstream sounded thin and clinical. While Crunch matched the 165VBs better by neutralizing it's brightness and it sounded more balanced while providing a bigger bodied sound. That was actually a costly mistake on my end, coz I already bought the Soundstream amp due to it's specs rather than listening to what my installer had to say.
audio set-up for beginners [continued]
