Results 1 to 20 of 3070
Threaded View
    Mar 2012
    glad to know you're keen in DIY. you mean it can go lower in frequency?
    Kailangan mag DIY sir dahil the nearest audio installer sa area ko is 300km away hehehe.
    What I mean po is I'll buy a sub na lang and build my own enclosure rather than buy a powered underseat sub.
    Underseat sub can only do so much. Yung kicker hide away underseat sub is around 16k, the Focal IBus kahit yung gen 1 is 20k above. DLS is going to bring in their own underseat sub but dont know when and magkano price. With that amount of money I could buy a JL 10tw3 shallow sub at around 17k, wider cone surface, longer excursion and more powerful kahit mga 0.34cu ft lang enclosure ko makaka produce ako ng mga 56hz at 0 db. Yun nga lang kailangan pa amp.
    I would be more than happy if I can produce kahit 50Hz dahil as per the graph below from WinISD app, mag roll-off ako at around 45hz.
    Fingers cross na tama input ko ng T/S parameters.
    This app also helps me decide if worth ba ang 17k na JL or ok na ang 5k na Infinity reference
audio set-up for beginners [continued]
