Page 113 of 154 FirstFirst ... 1363103109110111112113114115116117123 ... LastLast
Results 2,241 to 2,260 of 3070
    Aug 2010
    #2241
    *Siento
    But the problem there is that it induces another variable to the buyer: What amplifier sounds good? What amplifier sounds bad? When, in fact, the decision is extremely controversial.
    Fact is: Not all amplifiers sound the same
    So I'm not too surprised if the Crunch amplifier may sound better. After all, it might have a better low-end response wherein it boosts certain low end frequencies (Rockford used to do this and their customers loved it). But what if the inherent vehicle acoustics has a boomy low-end where 100hz has a huge peak? Then the Soundstream's "thin and clinical" would give a better balance than using the Crunch that would have exaggerated this peak further.
    It's a very much case-to-case basis and there are a lot more variables affecting the sound. In order, they're probably:
    1. Vehicle Acoustics
    2. Speaker Positioning
    3. Tuning (EQ, Crossovers, Phasing)
    Then there's the fourth criteria: speaker sound signature. After that are minor variables coming from amplifier sound, cable impedance differences, etc. Then again, this is pretty much my opinion on it.
    Jun 2009
    #2242
    Need help / advise mga sir planning to add 2x8” infinity ref 250w rms at 4ohms to be connected in parallel (500w rms at 2ohms) connection. Ok kaya ang Sound Magus DK600 or DK1200 both can handle 600w rms at 2ohms.
    Or i will chose from other mono amp. brand like
    JBL GT601- 600W at 2ohms
    Ground Zero Iridium- GZIA-1.100DX – II – 650W at 2ohms
    Helix G One – 675w at 2ohms
    Which one would be best to suite those 2 subwoofer and I am planning for a sealed enclosure.
    Feb 2017
    #2243
    2012 honda city, i want to upgrade my car audio. =)
    I listen to OPM and RNB and love songs and some alternative music. I am on a tight budget so i look for used stuff too for this project. Meron na po ako nahanap sonus 4.100, ibebenta sakin hopefully for 8000 anytime next week. Naka pioneer avhx 5850 ako ngayon sir, bought it for 8000 din. and Blaupunkt underseat subs for 3000. gusto ko palitan yung subs sir parang kulang po sa bass. Naka MB Quart formula seps din po ako pero papalitan ko din kasi basag yata isang midbass speaker. ano po yung ma recomend nyo na seps para sakin? ok ba ang flux sporty? mag nagbbenta din po sakin na used Focal ps165f for 13k.
    Hope you can help me Sir/ Mam =)
    Any addtl input is highly appreciated =)
    ty po
    ps siguro po naisip nyo na ngayon na kuripot po ako hehehe
    #2244
    kapag 100w rms amplifier ibig sabihin ba 100w sya kapag naka max yung gain
    Dec 2007
    #2245
    Quote Originally Posted by armour View Post
    Any of those mono amps on your list will do.
    You can always opt for a single sub on a ported enclosure with any amplifier you mentioned.
    Sent from my SM-A800F using Tsikot Forums mobile app
    Jun 2009
    #2246
    thanks sir markgy
    kaya dual 8" ang ilagay ko balak ko kc gayahin ito,mukhang kayang gawin
    by the way ang maximun dimension na kaya gawin bawat box is L-19" x W-12" x D-8"
    Jun 2009
    #2247
    I will be using ½” MDF, wala kc ¾” available dito sa amin
    By computation I will have 1386 cub inch divide by 1728 to get the cubic feet .(this idea comes from GOOGLE)
    I will have appx. Of 0.8 cubic feet, Infinity Ref 8” requires only 0 .35 cubic feet.( values from Infinity)
    Much of my understanding / knowlwedge comes from google and youtube he he he he...
    If will go to ported box, i have NO IDEA on the size of port opening
    Can anybody point me on how to do a ported box
    Dec 2007
    #2248
    Hehe sa binagay mong values pang 3/4 ang computation mo.
    We are you from? Baka maka recommend kame ng magaling na installer near your area.
    Re. Ported enclosure, maraming box calculators online. Try the RE box calculator (Resonant Engineering) site.
    Dec 2007
    #2249
    Quote Originally Posted by nixce View Post
    ty po
    Sumali ka sa "car audio swap" group sa facebook maraming ka makikita 2nd hand items doon.
    Dec 2007
    #2250
    Quote Originally Posted by aprilboyidol View Post
    Yes, but you dont need to max out the gain to get the full potential power of the amplifier. Once you set the gain knob of the amplifier equally to the voltage signal output of the HU you are already using 100% of the power your amplifier is giving.
    Mar 2005
    #2251
    Help po mga sirs, I recently replaced my Kinetic KD 800.1 Mono amp to a Category 7 1000.1 mono amp. First time to DIY and when I finished installation, may malakas na whining sound ako na ririnig sa front separates. If I remove the RCA from the Head Unit to the Input of the Mono amp, nawawala yung whining sound.
    My previous setup was working fine naman and before I bought the category 7 mono amp, na test namin ng seller and wala whining sound. Napansin ko lang pag On ng ingnition iilaw yung protect LED ng mono amp for about 3 secs then mawawala and i ilaw na yung power LED niya. Is this normal?
    Could it be insufficient grounding? I double checked my connections naman and secured it properly.
    Jun 2009
    #2252
    hi sir markgy, thanks for the advise and answering
    sorry i am in the province of MAGUINDANAO i cannot find a good car audio installer he he he he..,
    so my route for the subwoofer box will be DIY, more fun and challenge but lack of information
    by the way my box dimension L-19"xW-12xD-8" each
    I minus all size by 1" since I have a 1/2" of MDF to get my internal dimension which is 1,386 cub. inch and divide by 1,728 to get 0.80 cub. ft.,
    I can easily make it to 0.35 cub. ft as recomended by Infinity for sealed enclosure, by putting a wall making my L-19" to L-9", which will give me a appx. 0.35 cub ft.
    If my enclosure is thin for 1/2" I can do a double wall which will make it to 1" and re do all the calculation.
    But I heard alot of good reviews on PORTED ENCLOSURE, thats why i need help / information on this on how to do this project DIY box
    Infinity recomended a 0.65 cub. ft of volume for ported subwoofer box they give a size of port opening of 2.5" but the depth is 8- 13/16", and my box is internal is only 7" and my speaker depth is 5-3/16" can i do the depth of port to 4.5", would it do any bad effect on the sound quality of subwoofer.
    Is there anything I can do make a ported enclosure or I will stick to sealed na lang.
    Feb 2017
    #2253
    Hi sir,, in my own opinion, sealed box is better. More accurate, hindi delayed ang bass, tight, swabe pero wag mag expect ng gumagapang na bass. Anyway, yung infinity subs m, pang SQ naman, so masarap yan bumayo sa sealed box. Hehe malambot. Tama ba ako? Naka sealed box yung infinity subs namin, kaya nasasabi ko yan. 12". Pero sa RnB na music, ok padin naman,, hindi masakit sa dibdib.
    Dec 2007
    #2254
    Oh tama pala ang computation mo for the sealed enclosure. I forgot I did enter .5 for the wood thickness.
    Sorry about that!
    Anyway, maybe this would help..
    Jun 2009
    #2255
    * sir NIXCE, thanks for sharing youre experience / info on infinity sub woofer, by the ano dimension o size ng sealed enclosure mo? (L x W x H) para may idea ako about sa gagawin ko, I already purchase 2x8" Infinity sub.
    ang alam ko tayo ang masarap bumayo he he he he he he...
    * sir MARKGY, thanks for answering ang giving some inputs on subwoofer enclosure, by the way ano gamit mo na software?
    Yun binigay mo na info about RE L- Ported Speaker Box Calculator mukhang pasok ako dun sa design nila at mukhang madali gawin.
    RE AUDIO - Box Calculator
    now I can order my power tools for my DIY project
    Jun 2009
    #2256
    is it possible to have 1" of L ported sub woofer box and tuned to 42hz?
    Aug 2010
    #2257
    Quote Originally Posted by jmpet626 View Post
    Yes. It's a wiring problem so you're picking up the whine. Sadly, correcting the problem takes time. Double check the connections as a start then rewire it.
    Aug 2010
    #2258
    Incorrect. Gain is NOT wattage. It is used to attenuate the signal more than anything. This widespread belief that "gain = wattage" is why people start blowing up their speakers and amplifiers.
    For those who wants to understand the concept of the gain knob on your amplifier, do read this link: Amplifier Gain Controls
    - this fully explains what it does and the concepts behind it
    - way better than me typing out another wall-of-text paragraph
    Aug 2010
    #2259
    Re: Ported versus Sealed
    Personally, I prefer ported enclosures.
    Both concepts have their own pros and cons. For example, technically, sealed boxes will always have higher distortion than ported boxes for a given output while ported boxes will always have time-delay related issues.
    - a sealed box is not "SQ" compared to a ported box. That's like saying a Php160,000 JL Fantom 15" subwoofer is not "SQ" because it's ported.
    - the time delay concept is one of the reasons why people suck at tuning ported enclosures. However, it isn't night and day difference and that problem is only applicable to the hardcore 1%.
    All those misnomers people throw "tightness", "loose", etc. are all analogies that refer to an improperly tuned SYSTEM. It is because people fail to tune their midbass to integrate seamlessly with their subwoofer that you get sloppiness. It's not because of your box.
    - I mean, I'm typing this in front of a Dynaudio Excite X12 loudspeaker and it's singing with a port. So is my computer setup with the Klipsch R-15PMs which also has a port.
    The reason why people in "SQ" prefers sealed is because it's easier to get it right. However, I've sat in cars with beautifully tuned ported enclosures and it has its own fair share of WOW moments (for example, Mike's Php1.3M full bewith system incorporates a 8" bewith subwoofer in a ported enclosure; so is their midbass ALSO on a ported enclosure).
    Mar 2005
    #2260
    Quote Originally Posted by jhnkvn View Post
    Was able to solve the whining noise by adding a ground loop isolatro between the RCA output of the HU and RCA input of the mono amp.
audio set-up for beginners [continued]
