Originally Posted by
markygy
It is still advisable if you can purchase your audio gears from a shop that can do the install as well. This is for after sales support. Anyway, for your budget, you might want to consider the Audio System MX-line 4.75 to be paired with your focal seps. It costs less than 15k the last I saw it online.
If I where on your shoes, susubukan ko muna yun nabanggit mo na NETWORK mode sa HU with the amplifier that you have. If your wondering how you will wire the speakers to your amplifier. Eto po ang gagawin nila. Assuming that the Front RCA of the HU was used for the signal for your seps and the rear RCA of the HU was for the coaxial. Since naka kabit na ang amplifier all you have to do is remove the passive cross over that came with your seps. The wire for the tweeters will go to channels 1&2 of the amp and the wire for the midbass will go the channels 3&4 on the amp. Bale tatangalin mo na yun coaxial speakers mo since the 4 channel amp will be dedicated for the tweeters and mid-bass. With a ACTIVE configuration, you can now control the level of the tweeters using the HU. Do not forget to set the HU to network mode and setting the levels of the amp's filters to all pass or off before doing your wiring
Wiring your speakers active needs good understanding po. Making all the right wiring is one thing while tuning the speakers active is another. Better to have a shop do it for you if this is your first attempt on wiring your speakers active.
Good Luck!
