Quote Originally Posted by ealdree View Post
currently, my amp is powering both the seps and sub. my setup was done by a car audio shop in las pinas. i was told by the installer that the crossover was set to -3db. i was looking for a more output from the tweeter so i brought my car to bp1 car audio in binan. the guy there told me that we need to put additional wiring because the first installer just used a sort of splitter. so the additional wiring was connected and he made some adjustments in my 5750bt hu and amp. the bass was softened and the sound was a little bit clearer. he advised me to replace my amp with dc 120 x 4 amp because my existing amp is overpowered by my firland ev612 seps that caused my amp to heat fast.
Baliw naman pala ang 1st installer mo. Based on what you mentioned, it seems he only used one RCA cable and used a Y-connector to split the front signal of your HU for the seps and subs. The 2nd installer added another RCA cable so the front signal goes to the seps and hopefully the sub-out signal for the subs. Would you check if you can control the volume levelof your subs using the sub level control on your HU. Paki confirm muna bro before I continue. Let's see if we could do something 1st with the install before you spend for a new amp.
