Page 125 of 307 FirstFirst ... 2575115121122123124125126127128129135175225 ... LastLast
Results 1,241 to 1,250 of 3070
    Dec 2007
    #1241
    Quote Originally Posted by zen.. View Post
    4 channels po. Ch 1 and 2 naka bridge for the sub . 3 and 4 sa front speaker. Na pag alaman ko po na distorted lang is yung ch 3
    Uhhm boss, when connecting a 4 channel amp to a pair of front speakers, make sure to connect the speakers wires to channels 1 & 2 of the 4 channels amp. This is because in general the front signals of a 4 channel amp is located on channels 1 & 2, while the rear signal is on channels 3 & 4. Para lang po tama ang install ninyo.
    Ang tanong ngayon is where did you set the filters of the amplifier on channels 1&2 and 3&4?
    Dec 2007
    #1242
    Quote Originally Posted by enargie View Post
    Sir, need advise for the specs of 4 channel amp I need to choose to power a 10" sub and a pair of 2-way seps.
    Thanks
    It will depend on the power requirements of your chosen seps and sub before you can match it to a 4 channel amp.
    #1243
    Quote Originally Posted by GTi View Post
    Ang hassle pala. Ang hirap ipagawa sa casa since wala talagang oras. Alam mo naman... Schedule pa ng appointment, ang haba pa ng pila, makipagkulit-kulitan pa sa mga warranty personnel nila and so on and so forth.
    But then again, bat natatanggap pa ang GPS SD card? Kung sira yan diba dapat pati yan di nababasa?
    Marupok ba talaga tong mga OEM AVT head units?
    Sent from my GT-I9100 using Tapatalk 2
    maybe you could have your head unit directly serviced at winterpine araneta ave., supplier of the avt brand
    Mar 2012
    #1244
    Sir jhnkvn, I know familiar ka sa mga JBL. I was able to download 2types of GTO609 pdf spec sheets. When I was reading both spec sheet and compare it to the pdf owner’s manual may pinagkaiba pala (RMS and frequency). I want to ask which is which. Maybe new and old model, but how would a newbie know which is the old and the newer model?
    Here is the screenshot:
    Jun 2014
    #1245
    Bro mcintosh na head unit kaso butas bulsa
    #1246
    mga paps...patulong...i have HSK 163 (3-way), amp would be LRx 5.1k and I'm planning to have it semi-active. But not the usual 3-way semi-active wherein TW+ Midrange for amp A-channel in A-pillar, and Midbass for amp B-channel. Question is:
    would it be advisable na ang TW for A-channel, and midrange + midbass for B-channel? Midbass would be in stock location(door molding), and midrange would be in kick panel, while the tweeters would be in a-pillar?..
    doing so will make the soundstage larger and for additional depth? and to avoid that "in your face" sound?...
    what would i be facing in this kind of setup?
    TIA
    Jun 2010
    #1247
    Quote Originally Posted by markygy View Post
    I already have a morel maximo 2 way seps and planning to get a 10" morel primo subs. With these gears what specs of amp would you suggest, Thanks
    Mar 2013
    #1248
    Can anyone recommend a decent slim type subwoofer that will fit under the seats of the new honda jazz GK?
    Posted via Tsikot Mobile App
    Feb 2011
    #1249
    if I'm not mistaken, there is enough space below the rear seat of the Jazz. You can fit a custom sub there. Jonz of Simple Sound creates one. This is better than any over-the-counter sub you can buy from stores.
    https://www.facebook.com/pages/Simpl...08193979267863
    Here's his digits:
    +639176885170 landline 7926695
    Aug 2014
    #1250
    Hi what's the usual service fee for taking out the 4 stock speakers and installing new ones? One is asking 500 per speaker. Do you know of any shop in Pasig Ortigas area that does this competently (correct and clean installation)? Thanks for your reply.
audio set-up for beginners [continued]
