Page 52 of 154 FirstFirst ... 24248495051525354555662102152 ... LastLast
Results 1,021 to 1,040 of 3070
    Aug 2010
    #1021
    Quote Originally Posted by Buging_King View Post
    Question guys. Sinu-sino po naka-underseat or bazooka type na active subwoofer dito? I was planning to buy one, pero i need your input kung alin sa dalawa ang maganda. Gusto ko lang naman po na may konting BASS yung mga songs ko from 2650ui. TY sa mga sasagot po.
    Requirements ko po eh, may remote to control yung bass response niya mapa, unerseat or sa trunk.
    A bazooka type will almost always be better.
    #1022
    Question about rear speakers. Kailangan ba yung may tweeter din, or speaker only? Lahat kasi na nakikita kung coaxial speakers may tweeter na kasama.
    Aug 2010
    #1023
    Quote Originally Posted by forrester_2010 View Post
    For rear speakers, I prefer a midbass only approach then a fade to the front speakers. Using a tweeter to your back will steer your image from the front to the back.
    Aug 2012
    #1024
    Quote Originally Posted by jhnkvn View Post
    What if separates din ung gusto ko ilagay sa likod? Ano mga need ko baguhin or do i need an amplifier na?
    Aug 2010
    #1025
    Quote Originally Posted by R.Paul View Post
    Not advicable. First is the problem on where to mount the tweeter. Unless meron ka yun between-the-doors tweeter mounting ng mga more expensive cars (such as a Range Rover), where do you plan on mounting the separate tweet?
    Second is that as long as there's a tweeter, agad nahahatak na yun imaging mo palikod. Normal folks won't probably care but the more enthusiast amongst the car audio crowd will frown upon a tweeter inclusion. Bass sounds are harder to locate kasi.. a very good example is that most computer 5.1 systems has the 6" subwoofer on your feet. But you don't hear it coming from there do you? Pero kung binababa mo yun front speakers mo (with usually either has a 2" full-range driver or a 1" tweeter), agad nahahatak yun sounds pababa.
    Aug 2012
    #1026
    Thanks bro. I have a six speaker factory setup with seps at the front. I'll just replace my stock speakers at the back with coaxial speakers for my rear passengers. Medyo bitin kasi ung sounds sa likod.
    #1027
    Thanks. Tama lang yung decision ko to just buy the separates. Retain ko na lang OEM speaker sa rear.
    #1028
    i have a kenwood 6033 head unit & focal ps165v seps. choosing between a) the ibus 2.1 active sub & using its built-in 2ch amp to power the seps or b) either the gladen m-line 75.4 or focal fd 4 350 or fpp 4100 & replacing the rear oem speakers w/ focal pc165. which is the lesser of two evils?
    Aug 2010
    #1029
    Depends on what you want.
    The cheaper option will be to get the Gladen 75.4 and getting a subwoofer + box.
    #1030
    if a sub+box were out of the question due to space constraints, would coaxials on the rear doors "help" an underseat sub do its job of delivering the lows? tia
    Aug 2010
    #1031
    Quote Originally Posted by bn9 View Post
    Unless you know how small a 0.7cu.ft sealed box is, I doubt space constraints would trump your list of worries about it. That's roughly the size of a small microwave.
    There's two things you need to know about the "lows". One is extension and the other is output. Slapping coaxials at the door will help you with output on the regions above the crossover (let's say your typical 80hz upwards) but it won't help you with extension.
    I'd still recommend going for a subwoofer. Even a small sealed one will work wonders in giving you a low-end bass. Habol mo lang dyan is more of extension over anything else (as a bonus, one 8" is like two 6.5" in output). Something like an 8" Infinity subwoofer on a sealed box should cost you less than 7,000php and should go down according to how much the installer charges you for the box.
    The reason why I'm not a fan of the iBus is that it's helluvah expensive item for the performance you're getting.
    #1032
    thanks john
    #1033
    *jhnkvn, quick question...I have 5K. can you give me specs to maximize my money to have a good sound setup?
    Aug 2010
    #1034
    Just buy any speaker that fits within that budget. Get the brand you think it best. Why think? Because there's not much differentiation on lower-end speaker units. There's only so much 5,000php can get you on material costs.
    #1035
    thanks man... actually i don't have any idea what brand that will fit my budget. Aside from Blade store, where can i buy?
    sorry for the noob question...
    Aug 2010
    #1036
    Quote Originally Posted by artbreaker View Post
    Lots in Banawe area. It isn't a Mecca for car parts for nothing
    Feb 2012
    #1037
    Mga sir need your advice, gusto ko lang po yung "surround" sound sa loob ng oto, anu po kayang sound set up recommended?
    Btw my HU is pioneer deh5350ub, di rin po pala ako pede maglagay ng sub sa trunk kasi lagi po may laman sa likod.. TIA mga sir!
    Posted via Tsikot Mobile App
    Jul 2011
    #1038
    #1039
    hahahaha okays, thanks man... medyo malayo kasi samin ang banawe eh.
    *aZzip - ask jhnkvn: he is the Master of the Master in sound set up
    Feb 2012
    #1040
    *artbreaker thanks sir! Sana nga mabasa to ni sir jhnkvn..
audio set-up for beginners [continued]
